I would recommend tapping to a larger size for those with the carbs off the bike.
And only stepping up 1mm, if you use a tapered tap, you should be fine.
You COULD drill it to tap drill size first, but thats going to make even more metal chips to deal with, beyond what the tapping will produce.
l8r
