I'm having one heck of a time cleaning the oil passages.
I don't know if this GUNK that's in there is the result of the submersion in water that caused the bent con-rod or what, but there was a LOT of reeeeally fine sand caked up in the oil passages in the case...I managed to get all of that out, and I'll follow with more solvent and blow it out with air tomorrow...the REAL issue is the crank.
Now, none of my journals are scored, the bearings were still in good shape...BUT. The oil holes in the crank were plugged up with this same gunk/sand combination...I'm beginning to think this thing was rescued from the bottom of a strip-mine that had filled with water...it's cleaning up pretty good except for the aforementioned crankshaft oil passages...
There are what looks like four allen headed plugs on the crank counterweights that look like they've been peened in place?
I could just go buy a crankshaft...but I'd really rather not. I was just wondering if anyone else has encountered these, or a similar situation...I don't want to go through all this on a rebuild only to have to buy all new stuff when it stops oiling due to blocked.....uhm....oiling.
how to get them out? Or maybe a better way to get the junk cleaned out without it?
