Author Topic: sprocket gearing question  (Read 2512 times)
Offline heffay
« on: May 01, 2008, 02:48:26 PM »
92 zx7r
going from 15 tooth front to stock 16 tooth
going from 44 tooth rear to 46 tooth
someone on here was even able to crank out percentages w/ other questions of this type... what say you?
Offline tbpmusic
Re: sprocket gearing question
« Reply #1 on: May 01, 2008, 03:18:42 PM »
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline heffay
« Reply #2 on: May 01, 2008, 03:42:46 PM »
thanks man!
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: May 01, 2008, 04:15:28 PM »
So in other words, no real change. :)
Offline heffay
« Reply #4 on: May 02, 2008, 06:55:09 AM »
yep... just a tiny bit.
i was actually trying to go the other way with it thinking that i had a 16 on the front and that would not change.
but, since i went up in the front and down in the rear... it was not geared down but very slightly up.
tis ok... speed is good.   ;D 8) ;D
p.s.  that top speed is about 5-8 mph too low.    ;D   if there were no speedo error.    ;)
Offline heffay
« Reply #5 on: May 02, 2008, 06:58:20 AM »
i like how it has me shifting into 6th at 144mph  ;D :o ;D
"yea... i just kick it into over drive at a bit under 150 and just cruise."   :D
Offline tbpmusic
« Reply #6 on: May 02, 2008, 07:58:57 AM »
What, you mean your bike won't do 144 mph+  ????
What kind of junk do you ride anyway ??!!  (Scoffing derisively).
bill
Bill Lane
Offline heffay
« Reply #7 on: May 02, 2008, 11:31:01 AM »
bill
you may have misread... it'll do it  ;)  although, i prefer to shift before 144mph  ;)
i've seen an indicated 155mph on a barren road at about 7,000ft above sea level... yes, the bike has mods  ;D 8) ;D
... piece of junk.   ;)
here, pretend you guys haven't seen it before   ;) :D...
Offline tbpmusic
« Reply #8 on: May 02, 2008, 06:19:34 PM »
Yoiks !!
I was just yankin' your chain - that's WAY too fast for me, thanks.
bill
Bill Lane
Offline cb650
« Reply #9 on: May 02, 2008, 06:35:11 PM »
A 6 speed??????????  Dont your hand and foot get so terribly over worked with the several billion extra gear changes?????????? ;D ;D
« Reply #10 on: May 02, 2008, 11:03:34 PM »
Basic gearing calculation..
 Driven = ratio
 Driver
Offline heffay
« Reply #11 on: May 04, 2008, 08:48:01 PM »
 Driven = ratio
 Driver
probably could've looked that up, but... you know.   ;)
here, have a look...
oh, by the way... PO's idea of torque settings:
manual calls for 54 ft/lbs on rear sprocket nuts... set to about a gibillion ft/lbs requiring two busted sockets, a week-long wound having yet to heal on my bird finger!, and a rubber mallet as the enforcer.
manual calls for 75 ft/lbs on the engine sprocket nut... nut was loose on threads w/ a large washer w/ bent edges locking the nut from spinning.
i have yet to find much of the bike put back together the way it came... funny thing is, the guy was a knowledgeable mechanic.  guess he just didn't own a torque wrench.  or, he threw it when i usually try not to... even in a maddened haze i have the presence of mind to not hurl calibrated instruments.   8)  unless of course they are intended to measure hurling velocity.   ;D  <frat party toy?   :-X
anyway... shop manual says nothing of this "safety washer"... aftermarket?
« Reply #12 on: May 04, 2008, 10:43:09 PM »
Nice sprocket...
