Author Topic: my CB750F build into a CR750 cafe  (Read 62615 times)
Offline jaguar
Re: my CB750F build into a CR750 cafe
« Reply #150 on: September 19, 2011, 04:47:20 AM »
Where do you find this info?
On this board
In a thread on stoker motors, They called them RC45 pistons
Offline jaguar
« Reply #151 on: September 29, 2011, 07:23:46 PM »
The friend that i bought the bike from dug up some old pictures of it from before I owned it.
She really was close to the road and I was dumb to strip it down.....I have learned SSSSOOOOooooo much since then.
Hopefully one day this bike is done.
Offline jaguar
« Reply #152 on: October 20, 2011, 11:46:25 AM »
Im thinking about throwing a stockish motor in it just to the bike to the point of wiring and running
Offline hapakev
  • Your Standard
« Reply #153 on: October 20, 2011, 11:57:32 AM »
I dont blame you for wanting to ride her.  You have a great build going on here and I cant wait to see the final outcome.
Smoking Jack
1978 CB750F(ish)
Offline srbakker
  • Spam & Eggs
« Reply #154 on: October 20, 2011, 07:40:23 PM »
Love what you're doing with this beast.
A quick question: how does the Vapor speedo work?  Does it have a Hall effect sensor/magnet?
And I assume the tach wires into the coils?
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline jaguar
« Reply #155 on: January 26, 2012, 07:49:00 PM »
Vapor is great
uses a magnet for the speedo and the tach is and induction pick up on coils
Offline jaguar
« Reply #156 on: January 26, 2012, 07:53:14 PM »
Well in an attempt to get my butt in gear my plan is now to put the stock motor in the bike to get it going and on the road.
after that V2 will be the full race yoshi motor that i have for a different bike and then V3 with monster.....but at this rate motorcycles might not even have wheels when i get there....lol
Got some cool carbs for this project.
I will be soda blasting and rebuilding them soon.
One of the chokes is broken but alittle JB should sort that....unless someone has a spare
Hope to have the motor painted and installed by next weekend
Offline jaguar
« Reply #157 on: January 30, 2012, 11:46:34 AM »
Rebuilding the dirty carbs
numbers on the manifold.
not really sure what manifold it is.
Offline Freaky1
« Reply #158 on: January 30, 2012, 12:41:28 PM »
This has been a great read, I've been going back through some of my favorite threads lately needing that "boost" and forgot how much I like this bike, very nice work.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline jaguar
« Reply #159 on: February 01, 2012, 10:53:22 AM »
Thanks, its been a long road....I do the same thing from time to time.  some great threads here
Offline jaguar
« Reply #160 on: February 01, 2012, 10:53:34 AM »
All blasted and washed.
Anyone have an extra chock knob?  Or know of a good place to get rebuild gaskets?
Offline jaguar
« Reply #161 on: February 01, 2012, 02:58:25 PM »
Small detail
Offline jaguar
« Reply #162 on: February 16, 2012, 08:19:19 PM »
Mostly because I cant help myself.  Im waiting on gaskets for the mikunis but thought that it would be fun to try some dellortos as well.
Thought that it would be cool to have a mikuni set on one bike and the dellortos on the other.  I really would like to have the manifolds remade...
Best laid plans......well I thought that the weber-dellortos-mikunis were all the same mounts....guess I was wrong
Will ill still clean these up and see what I can do with them
Scored a ARD mag set up cheap
It needs some work but the important bits are there.  Also have a pair of working tractor mags on they way to mix and match the needed parts
The ARD mag is a fairbanks unit that was milled to fit the CB750 mount.
Goal is to have a working mag thats not a grand....wish me luck
School and my CBX have been taking up most of my time but would like to get a motor in this thing asap and get this project in gear
On a side note.....anyone have any options of installing a side kick stand on a frame with no brackets and has already been powder coated?
Offline jaguar
« Reply #163 on: March 08, 2012, 12:57:03 PM »
All rebuilt and cleaned.
They are not going to be run on this build, they are going on a set or weber manifolds (that actually work with these carbs) and used on a cool period cafe bike.
Cleared out alot of other stuff from my plate to try and focus on this bike.
Offline jaguar
« Reply #164 on: April 17, 2012, 12:20:18 PM »
Cycle City Classics HD unbreakable primary chains
M3 Racing HD primary bushings
Santee pipes
Not sure about the pipes.  kinda dont like the mufflers but it clears my center stand so.....
If
Offline Ricky_Racer
« Reply #165 on: April 17, 2012, 12:25:22 PM »
Okay, Jag, so WTF happened with all the drama around id'ing and getting gaskets for the Mikuni-Solex carbs? Last I heard the supplier said they couldn't help you. Were they right, or wrong? And what did the carbs finally turn out to be? RR
Offline jaguar
« Reply #166 on: April 17, 2012, 08:48:28 PM »
well wolfcreek was not able to help me at all.  They kinda knew what they were but said that they will not deal with motorcycle parts.....SOOooooo
From what i can gather some people call them type Q but not many.......
They are 36mm and a completely different casting then the 40s so they dont fit where a weber or dellorto would go, but they are smaller and lighter so its give and take.
There are ZERO parts out there for them.  i would kill for a set of stacks. and dont even get me started on gaskets....
http://www.fiatplus.com/home.php
These guys seem to be the most help so far.  They have no idea what the carbs are but some of the fiat gaskets look like they will work, and ive read that the 32mm fiat/lancia stuff will work on these.
I have talked to
sudco
mikuni motorsports
mikuni international
fiat dealers
lancia resto guys
wolfcreek
some carb guy in Australia
The guy that made the manifold, Branch
Few old racers
some harley guys because they run a single on the sportsters from time to time back in the day
Im ordering the parts from that link and it should be all i need to get rolling
I think that there are filters that are available but not stacks
How complete/dirty are yours?
Offline Ricky_Racer
« Reply #167 on: April 17, 2012, 10:03:01 PM »
Okay. Roger that... For some reason I mistakenly thought you were using your Mikuni-Solexes.
Not sure how mine are internally. The outside could use a good sodablasting and detailing, but I have a feeling that the insides are pretty good. Plus they have that cool Jerry Branch cast air filter and two-piece intake manifold.
Guess I'm gonna have to break them out from storage and see if I can get a gasket kit since these are the more "normal" size carbs. I'll let you know how it goes when I get around to it. RR
Offline jaguar
« Reply #168 on: April 17, 2012, 10:24:22 PM »
I am running my mikuni solex carbs
The 40mm dellortos are going on a friends
Your mikunis are 40mm?
Offline Ricky_Racer
« Reply #169 on: April 18, 2012, 12:37:41 PM »
Yep.  RR
Offline jaguar
« Reply #170 on: April 20, 2012, 07:19:42 PM »
Still collecting parts...
Saw this and thought that it was cool.
Maybe I was on to something with the small Honda slave.
Not sure if this is a fishhead kit or just a copy
Offline jaguar
« Reply #171 on: May 01, 2012, 06:54:41 PM »
Well I scored a RC unit.  Actually two so if anyone has a kawi and wants one PM me.
Since school and such are taking up most of my free time I have not gotten much done on the bikes
I figured I would mock some stuff up just to see and light a fire under my ass.
As soon as classes are done the plan is to get the bottom end built and installed.  I have all the parts i need.
Offline jaguar
« Reply #172 on: May 16, 2012, 05:25:10 PM »
Starting to clean up the engine cases for paint
Plan is wrinkle black.
Pork chops anyone?
Offline Flying J
« Reply #173 on: May 16, 2012, 11:30:40 PM »
Dont want to alarm you but I dont think that head is going to work on your motor. Send it to me and ill find a suitable one for you. ;)
Offline jaguar
« Reply #174 on: May 17, 2012, 05:55:13 AM »
LOL.
Yeah was cleaning up the head for my CBX at the same time.
The CBX motor is going back together this week
