had the same problem after rebuilding them k7/8 carbs,the choke butterflies would move only when you move them by hand(touching the butterfly valves) but not when you moved the top mechanism,drove me nuts,till i compared the pressure to another set of carbs,,, the buttlerflies seemed loose enough but they weren't they were binding in the bores,,had to adjust the butterflies(two screws each) a milimeter here and there sideways,they were binding a bit thats what causes the choke not to work,they have to have no binding anywhere for the choke to work with the chokecable
