Author Topic: need advice for front suspension overhaul on 1976 CB750 K  (Read 1027 times)
pbelanger
« on: May 08, 2008, 05:18:52 PM »
Greetings everyone,
My 1976 CB750 K is due for a front suspension overhaul. Oil doesn't seem to leak (in fact, I think it doesn't), but I find the suspension to be very soft when I push on it sitting on the bike. (bike at rest, leaning on the suspension, and pushing on it) Plus, when I'm riding, it feels "bumpy" a lot. I mean, every little bump I it, I feel like to only suspension I have is the front tire. It gets a little scary on high speed corners, as you can imagine. :)
If I was to order parts through eBay, what would you recommend?
I presume, since the tubes are good:
1) seals, as they are probably not that expensive?
2) springs?
Any other thoughts?
Thanks in advance for your help and considerable knowledge, as always.
Nest regards,
Paul
1976 CB750 K
Offline Gordon
  • 750K1, 550K2
Re: need advice for front suspension overhaul on 1976 CB750 K
« Reply #1 on: May 08, 2008, 05:56:42 PM »
Have you checked the level of the fork oil?
pbelanger
« Reply #2 on: May 08, 2008, 06:02:06 PM »
I must admit I didn't. But then again, that could explain why it's a bit bumpy. But the extreme softness while in "compression" mode? Wouldn't that be "spring" related?
pbelanger
« Reply #3 on: May 24, 2008, 03:19:59 PM »
Hi all,
Today, I finally found some time to look into this. First, I purged the old oil inside both fron tubes. Then added some fresh 10W30 and purged them again real good. Now, I added just what it says in the Clymer manual: 7.0 - 7.3 oz in each fork.
I went for a test ride. The thing was HARD as hell, worst than before. It really felt like the only suspension I had was the fron tire! I got back home and squirted 2 good shots off each tube and went again for a test ride. It's still really stiff. At rest, I could feel it wasn't quite right. I then squirted 2 more good shots off each tube. Now, it begins to feel smooth again, but it just isn't optimal.
Question: how much oil do you guys add when you fill each tube?
Thanks in advance for your help,
Paul
