Author Topic: moding 650 forks  (Read 1161 times)
isred
moding 650 forks
« on: May 13, 2008, 06:02:57 AM »
Hello all I have a odd question. Are CB550 and 650 forks the same length. And will the upper 550 tubes fit in the 650 bottom tube. Thanx for the replies Brent
Offline Muk
  • WHY OH WHY DIDN'T I TAKE THE BLUE PILL
Re: moding 650 forks
« Reply #1 on: May 13, 2008, 06:17:26 AM »
from what i have read the 650 forks are longer by about 25mm, but at this time i have no tangible proof to base this on. but i have a set of 650 forks on the way for my 550 as soon as i get the i may just experiment
1976 CB550K
1978 GS750E
1980 GS550E
isred
« Reply #2 on: May 13, 2008, 06:24:36 AM »
I thought that I had read on here that the 650 forks were longer than the 550 forks. That is why I want to put the 550 sliders inthe 650 bottoms.  For those that are wondering I want to put to put comstares on the 550
Offline Muk
« Reply #3 on: May 13, 2008, 06:52:41 AM »
thats what i am doing to min, i pick the wheels up  here locally but the forks ar e bay items
1976 CB550K
1978 GS750E
1980 GS550E
Offline Soos
« Reply #4 on: May 13, 2008, 06:59:55 AM »
If they are the same diameter I don't see why not.
I am currently running '79 cb650 upper tubes, and '79750(dohc) lowers for the dual disk setup.
For me everything went well with that swap.
Interesting finding another 650 owner named Brent though...
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
isred
« Reply #5 on: May 13, 2008, 11:17:39 AM »
Also I have progressive springs for the 550 forks and want to know if I can use them in the swap. I don't no why I couldn't but I thought i would ask while I am on here. And to Soos Brent is a rare name. Nice to see a fellow SOHC4 member with it. Thanx Brent
Offline Soos
« Reply #6 on: May 13, 2008, 08:52:17 PM »
yeah i thought it was rare... until I moved to utah.
have met about 10 in the last 4 years.
NONE in any other state.
WIERD......
l8r
-=≡ Soos ≡=-
Offline scunny
  • don't call me expert
« Reply #7 on: May 14, 2008, 01:27:52 AM »
if the 650 tube length is 25mm longer than the 550, then your springs would then be 25mm shorter than design. would seem to be easy to then fit a 25mm preload on top so you can use those progressive springs. as to what would be better, a stack of washers/spacer or another spring such as a valve spring, greater minds than mine would know that answer, either way I say yes
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
