Author Topic: What's the quickest way to tell if a bike's worth repairing.  (Read 4205 times)
Offline ger87410
Re: What's the quickest way to tell if a bike's worth repairing.
« Reply #25 on: May 14, 2008, 09:51:43 AM »
Thats an excellent suggestion Gordon.
  ..it looks like a newer frame with older components..
  With the previously mentioned frame details, its looking more and more like the VIN tag might be the only "newer"  part on your bike Ger.
Nope.  Had the wife check and the VIN number matches what's stamped.  Here's the VIN in case anyone cared: CB750K-2804732
It's a 1978 K frame as near as I can tell.
Offline sandcastcb750
« Reply #26 on: May 14, 2008, 10:48:07 AM »
Value? 2 things..................
1) Has a title?
2) Frame is undamaged?
Everything else can be managed. Either of the two above answers to "NO", you have parts and a heavy boat anchor.
My only exception is a CB750 sandcast. Most of the others have relatively low value.
Offline ger87410
« Reply #27 on: May 14, 2008, 11:02:51 AM »
No title.
By the sounds of it, a lost title is hard to get back...  Is that the case in most states?
It was pretty easy to get a lost title on our boats...
Offline Gordon
  • 750K1, 550K2
« Reply #28 on: May 14, 2008, 11:12:13 AM »
No title.
It varies greatly state to state, and a lot of places seem to be making it more difficult recently.  Just call your DMV (or whatever it's called in your state) and ask them what you'll need to do.
Offline ger87410
« Reply #29 on: May 14, 2008, 11:16:52 AM »
Ahead of U there.  The only thing I need to do in NM in fill out a form and bring it in for a VIN inspection.
Come to think of it, that's all I had to do on my boats...
Offline Gordon
  • 750K1, 550K2
« Reply #30 on: May 14, 2008, 11:21:17 AM »
Glad to hear it!  Apparently here in CO, they've made it close to impossible to get a title if the bike wasn't already in your name.
Offline Geeto67
  • A grumpy
« Reply #31 on: May 14, 2008, 11:45:20 AM »
This is kind of dubious.
your bike is definatly a 1969-76 model cb750K. There are no doubts about that because you would not even be able to get that seat mounted on a 77-78 frame without major welding. Plus a lot of the frame tubes are all wrong for a 77-78.
What you have on your hands is a bike somebody monkey-ed with the vin. The question is why?
- it could be a stolen bike. It would have been stolen a long long time ago but it is still possible. whether it could be traced back to you is another story.
- It could have been wrecked and to avoid a salvage title somebody retitled it with a 78 cb750 vin.
what are the motor numbers? maybe that would give you a clue as to the actual year of the bike (although If I had to guess I would say 75-76).
as to whether it is worth doing anything with? well depends on what you want to do. If you want to build a honda chop and are going to throw out the stock frame - as long as you have a good engine seems like the way to go. Otherwise, I would look for another early cb750 and use this sucker as a parts bike based on the questionable origin alone.
Maintenance Matters Most
Offline Gordon
  • 750K1, 550K2
« Reply #32 on: May 14, 2008, 12:04:10 PM »
Well, if the stamped VIN matches the tag VIN, and there's no evidence that the stamp has been forged, then you can at least be sure the steering neck is from a '78.
Offline mystic_1
  • 1970 CB750K
« Reply #33 on: May 14, 2008, 12:14:37 PM »
Let's see a pic of the stamped number.  It's nearly impossible to stamp new numbers and have them look like they're supposed to, to a trained eye.
mystic_1
- John Augustus Shedd
Offline ger87410
« Reply #34 on: May 14, 2008, 01:41:08 PM »
For your entertainment, I present the stamped number.
Please, let me know what your guy's thoughts are.
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #35 on: May 14, 2008, 01:46:06 PM »
Hmmm.  That doesn't look right.
1977 CB750
Offline Gordon
  • 750K1, 550K2
« Reply #36 on: May 14, 2008, 01:49:18 PM »
Just from looking at the picture, I don't see any obvious signs of forgery, but of course I'm not an expert.  What does stand out to me is that the last set of numbers is in a different typeface than the first.  On all my Hondas, the typeface is the same through the entire number, but then they're all '76 or newer, so something may have changed.
I like a good mystery! ;D
Offline dustyc
  • 1977 CB750K
« Reply #37 on: May 14, 2008, 01:58:35 PM »
They should look like this
Sorry for the blur, but you should be able to see the difference.
1977 CB750
Offline Gordon
  • 750K1, 550K2
« Reply #38 on: May 14, 2008, 02:01:16 PM »
Where's Angela Lansbury when you need her!? :D
Offline dustyc
  • 1977 CB750K
« Reply #39 on: May 14, 2008, 02:03:29 PM »
Hanging out with Matlock and Quincy???
1977 CB750
Offline ger87410
« Reply #40 on: May 14, 2008, 02:06:01 PM »
Looks like mine is a serif font and your's is a sans serif.
I'm assuming the VIN pictured came off a G1.  Anyone with a G2: is your stamp's font the same?
Could it be this is a frame to a DOHC and that's why the font's different?  I not sure, because it looks like the DOHC didn't come out till 79.....
Offline mystic_1
  • 1970 CB750K
« Reply #41 on: May 14, 2008, 02:12:40 PM »
DOHC frames are radically different.
mystic_1
Offline Gordon
  • 750K1, 550K2
« Reply #42 on: May 14, 2008, 02:12:54 PM »
Amazingly enough, they're all still alive!  So let's give 'em a call! ;D
Offline dustyc
  • 1977 CB750K
« Reply #43 on: May 14, 2008, 02:25:27 PM »
77 K
and 78 F
1977 CB750
« Reply #44 on: May 14, 2008, 02:34:31 PM »
DOHC frames in 79 begin with RC01
Your frame stamping looks forged, to me.  I guess at one time someone had a title for the 78, and then moved the plate and tampered with the headstock stamp.
Is the number on the motor tampered with, too?  My I.D. Guide has years for those numbers, too.
I wouldn't put ANY work into that bike until I had legal title or state ownership papers showing I owned it.
Offline Roach Carver
« Reply #45 on: May 14, 2008, 02:37:02 PM »
my vote is that it is hand stamped. If the photo is accurate the numbers are up and down and the type style looks all wrong to me.
Offline ger87410
« Reply #46 on: May 14, 2008, 03:37:14 PM »
The engine # is CB750E-2458161
What can you decipher from that?
EDIT: the engine number on the 1976 1 I'm riding is CB750E-2445866.  What year is that engine for?
« Last Edit: May 14, 2008, 03:40:04 PM by ger87410 »
« Reply #47 on: May 14, 2008, 04:56:32 PM »
CB750 1976 for both your engine numbers.
The 76 K model began with engine numbers; 2428762~
The 77 K model began with engine numbers; 2700001~
The 78 K model began with engine numbers; 3000001~
Methinks your bike began life as a 1976 K model before it had an identity crisis.
Offline ger87410
« Reply #48 on: May 14, 2008, 05:49:11 PM »
Thanks, guys!!!
I've got a third engine the chap gave to me when I bought the 76 CB.  It's vin is cb75e-1053916.
It doesn't fall into any of those categories.  Does that mean it's older?
« Reply #49 on: May 14, 2008, 06:11:31 PM »
Thanks, guys!!!
Yes, 70-71 K1 model.
