Author Topic: Maiden voyage last night, have some questions  (Read 774 times)
Mattydiah
« on: May 14, 2008, 06:35:13 AM »
Well, as the title says, I took my 77 750K on its maiden voyage last night.  What a fun bike!  I can tell I'm really going to like it.  I do have a few questions though.  For informations sake, it has a MAC 4-1 and pods, stock pilot jetting, and 122.5 mainjet.
When driving it at night, I notice that the lights get bright, then dim, every 30 seconds or so, like its going from generator+battery to just battery every so often.  Like I said, it seems to do this every 30 seconds or so, and it doesnt seem to affect how the bike runs at all, oddly.  Would this be a regulator issue?
Secondly, its pretty stumbly in the 1/4-ish throttle range, and seems to have some hiccups further than that, although I really didnt push it last night.  I am assuming this would be pilot jet range, and into jet needle range?  I know there isnt anything I can do about the pilot on a 77, except make sure its clean, which it is.  Should I raise the needle up a notch (are there notches or shims?), or what?  I am already running 122.5 mains.
Other than that, its doing good, and, like a typical Honda, it works almost flawlessly, despite being 32 years old.
I can tell I'm really going to love this bike!!
Offline Gordon
  • 750K1, 550K2
Re: Maiden voyage last night, have some questions
« Reply #1 on: May 14, 2008, 06:38:14 AM »
Don't start making changes until you know what's happening.  Do a plug chop at the throttle opening that you're having the problems to see what's actually going on.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: May 14, 2008, 08:37:26 AM »
Anyone have any theories on the regulator issue?
Not until you whip out your voltmeter and give us some test data to work with  :)
What's the battery voltage when not running, idling, and at 3000 RPM?  Describe your electrical system and ignition, if not stock.
Congrats on the first of your shakedown runs :)
mystic_1
- John Augustus Shedd
« Reply #3 on: May 14, 2008, 09:12:49 AM »
regulator contacts need cleaning and re-setting as per Honda manual
