Well, I've read through a lot of the other posts; "clutch issues", "CLutch!!! What am I missing" and "What am I doing wrong"... so thanks already for lots of good advice!
Here's my story with a few more questions;
1977 550K
The clutch will not disengage.
When the ignition is off, I can move the gears through 1N2 but not 345
When the ignition is on, it grinds into 1st and so forth.
When the bike is on and in gear, I hold in the clutch and the rear wheel still spins, and the idle acts like it's going to fail without a little gas.
I adjusted the clutch cable and screw by the book as well as what seemed to work better, but not it didn't fix it. -All on the center stand-
I took out the plates and friction discs and- there was plenty of rust to be removed- wet sanded them down to shine again...
1st Q: Should I even take the time to measure the plates and reuse or should I just assume they are toasted and get new ones?
-I will measure them in the case that they are keepers-
When I put them back in I noticed that each plate/disc had a round-edged side and a sharped edge on the other side. I believe that all the rounded edges were facing away from the motor.
2ndQ: does the rounded edge matter for direction? facing toward or away from the motor?
(Also, Just to clarify- the oil ridges on each disc are vertical, not diagonal and therefore do not have direction I presume?)
A friend told me that there are a few pins inside the clutch that could be disfunctional, so I ordered new ones, but I couldn't find pins or anything that looked similar in the clutch area. Would these pins be inside the transmission and therefore I might have to open the engine to find them? Anyone have experience with these pin-problems?
I noticed that people have spoken about measuring the springs- I'm assuming this refers to the springs under the pressure plate and not the springs that work with the gear arms? And I haven't looked/found measurement length for springs- any suggestion on where to find these lengths.
Also, under the clutch cover, loosely wrapped around the inside arm (which makes adjustments from cable to cam ramp engagement), there was a spring loosely wrapped around the arm and dangling two possible pressure-point arms. However I couldn't figure out what this spring would do, and there wasn't any signs of wear and tear showing possible usages.
3rd Q; any idea if this spring might control the ability of the arm? how?
On another note, She won't idle.
I adjusted valves, and filed down the points (may try new ones soon). I changed the spark plugs because somebody before me thought variety might be fun?!?
I tried to match the timing but couldn't get the idle down to 1,000-1,200 to test.
I'm thinking about cleaning out the carbs next.
I guess that is all for now- if you've got answers, pass them along- thanks!
I was told "TooTired" might have some good answers- Are you out there "TooTired" ?
