Author Topic: 4x4 exaust is it better than 4 into 1  (Read 1562 times)
gary-stidham
« on: May 15, 2008, 08:43:34 PM »
my biggest problem with this exhaust is my foot break lever hits it when i try to push down on it is it because it is not the stock exhaust or is it the wrong lever  oh i have a CB550k 1976    what is the difference between the k and f beside the tank and exhaust
Offline OldSchool_IsCool
  • Really feeling like an
Re: 4x4 exaust is it better than 4 into 1
« Reply #1 on: May 15, 2008, 08:50:15 PM »
The stock #4 header is crimped to allow the foot pedal to clear.
I think the seat is different too, due to the tank difference.  TT can give you the complete rundown on the differences.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #2 on: May 15, 2008, 10:46:57 PM »
I don't really understand the question.  Are you trying to put F exhaust on a K model?
The K model 550 has two header pipes to clear the brake arm.  The F model has four.  The F model has a thinner brake arm and it is offset further away from the frame.  The F model kick start lever is also offset for extra clearance, too.  Also, the foot peg is able to be flipped up to clear the kick start swing.
I thought all the aftermarket 4 into ones accommodated the K style brake arm?  Guess not...
gary-stidham
« Reply #3 on: May 16, 2008, 12:03:59 AM »
i have 4 separate exhaust pips but i like the look of the 4 into 1 better
i don't know about the kick start because it was stolen be for i got it
the break lever hits the pips when you try to push it down
Offline Klark Kent
« Reply #4 on: May 16, 2008, 12:12:29 AM »
kickstarters are the new catalytic coverter.  always getting my kickstarter jacked.
based on TT's post i think you wil be fine with an aftermarket 4 into 1 as they are all made to clear the brake lever travel.  But stock 550F pipes will not fit a K.
as far as if a 4 into 1 is 'better' it depends on what you mean.  It will increase 'performance' (not sure how much though)  and only if the proper adjustments are made to the carbs. (search for rejetting for 4 into 1 exhaust)
 i think 4 into 4 is better because i do not have to rejet my carbs, but that's just me.  (and they are a nice looking set of pipes!)
good luck
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline ekim98
« Reply #5 on: May 16, 2008, 05:15:41 AM »
Did they make a set of black CR 4 into 4 pipes to fit the 550k. I think those would look and sound great on a 550.  ;D ;D ;D
Probably still have to re jet but it would be worth it.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #6 on: May 17, 2008, 07:10:45 AM »
Is your rear brake properly adjusted? If its way out of whack, the pedal may go far enough to hit the pipe. I don't have a 550 in front of me to look at for any other clearance issues that may be there... Hope this helps!
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
gary-stidham
« Reply #7 on: May 17, 2008, 04:56:40 PM »
no the lever rests on the upword stop so it is on right
Offline cafe750
« Reply #8 on: May 17, 2008, 09:32:07 PM »
I meant the adjustment back by the wheel. If you have to depress the  rear brake pedal more than an inch or so before your brakes apply, then you need to adjust it.... ;)
Roy, Washington
gary-stidham
« Reply #9 on: May 18, 2008, 03:43:38 PM »
from the top stop to the exhaust their is no place for the break lever to go their is only about a half inch for the lever to go until it hits the exhaust
« Reply #10 on: May 18, 2008, 07:46:20 PM »
If they are better why dont we see more on racers??
Offline ekim98
« Reply #11 on: May 18, 2008, 10:53:15 PM »
Which racing class is running stock 4 into 4 exhaust? or are you saying the CR 4 into 4 exhaust is a stock item but just for racing. He is talking about a stock system is he not as compared to a stock f  4 into 1 system!
« Reply #12 on: May 18, 2008, 11:06:10 PM »
I think i read the title wrong...
 if his brake is hitting the pipes, should be easier to mod pedal than change pipes
Offline ekim98
« Reply #13 on: May 19, 2008, 08:39:32 AM »
I've been guilty of not reading things right more than once, but I'm sure getting older plays into that, and that's my story.  ;D ;D
