Author Topic: 73 CB500 idle issue  (Read 963 times)
thegoochking
73 CB500 idle issue
« on: May 16, 2008, 08:12:09 AM »
Hi i just started riding not to long ago and i was given a 73 cb500 from my pops, He said he changed the carbs and synched them already before he gave it to me. There is play on the throttle where i will have to push it back up toward the front break handle to get it to stop reving sometimes and i cant seem to get the bike to idle properly. If i bring it under 3000 it starts to stutter and the rpms just drop and it cuts off. Does anyone know how i can get it set so that it will idle at a normal number. Seems to also only stay up with the choke flipped up.
Any help would be greatly appreciated
please email me at thegoochking@gmail.com if anyone knows of a way to fix this.
p.s. I also have some oil leaking from where the foot shifter is comming from the engine.
« Last Edit: May 16, 2008, 08:17:04 AM by thegoochking »
Offline Muk
  • WHY OH WHY DIDN'T I TAKE THE BLUE PILL
Re: 73 CB500 idle issue
« Reply #1 on: May 16, 2008, 11:46:48 AM »
clogged low speed jets i would guess
1976 CB550K
1978 GS750E
1980 GS550E
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: May 16, 2008, 12:27:27 PM »
You need to clean the carbs (as Muk says)
Shifter oil seal needs replacing. Not difficult.
Buy new seal.
Remove shift lever.
Screw a couple of (wood)screws into the seal and pull it out.
Gently tap new seal in.
Replace shift lever.
Job done.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
