Author Topic: Wheel Bearings?  (Read 6574 times)
cjbear11
Wheel Bearings?
« on: May 16, 2008, 10:49:57 PM »
I need new wheel bearing on my front wheel.  What are the best to use, and where can i get them?  My bike is an '83 CB650SC Nighthawk.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Wheel Bearings?
« Reply #1 on: May 16, 2008, 11:04:38 PM »
Check the manual to see if it is a 'special' size that you can only get from Honda. Better still take the original to your local bearing emporium and they will tell you whether it is one that they can replace or one that you have to order OEM. The factory will always charge more for a replacement bearing that you could have got from a generic supplier.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
Re: Wheel Bearings?
« Reply #2 on: May 19, 2008, 04:03:12 AM »
Do the wheel bearings get cleaned and greased when the tires are replaced?  Or should they be?  Is it automatic for a good shop to do that?  thanks
Enjoying life, one day at a time.
Offline Johnie
Re: Wheel Bearings?
« Reply #3 on: May 19, 2008, 05:48:22 AM »
No, it is not automatic for the shop to clean & repack wheel bearings.  Most of the bearings are pre-packed and factory sealed and you can not take them apart.  You can not add more grease.  Even my 1970 had sealed bearings.  1 of the bearings on the front of my KO was loose and I could tell it was dry.  So I just replaced them both.  Then I figured I may as well do the 3 in back too.  Now I know what I am driving on have that piece of mind.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
    • bloggy thoughts
Re: Wheel Bearings?
« Reply #4 on: May 19, 2008, 07:12:13 AM »
Yeah peace of mind is good to have.  I didn't think about the bearings being sealed.  Makes sense, though.   thanks
Offline VTCBike750
Re: Wheel Bearings?
« Reply #5 on: June 03, 2013, 11:07:50 AM »
Does anyone recommend a brand, obviously double sealed, but just fishing to see if anyone has a recommendation for a 72 750.
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline CycleRanger
  • No comment about being an
Re: Wheel Bearings?
« Reply #6 on: June 03, 2013, 01:15:36 PM »
http://www.allballsracing.com/
Offline VTCBike750
Re: Wheel Bearings?
« Reply #7 on: June 03, 2013, 04:21:25 PM »
Thank you
-Adam
