Author Topic: My 75' CB750F is in need of a clutch jod. What is the best???  (Read 1462 times)
qcextreme
« on: August 22, 2005, 04:47:50 AM »
My 75' CB750F is in need of a clutch job. What is the best??? What this I hear about running a Goldwing clutch ("B" plate) or a 77 and up supersport?? My clutch has always been loud like a rattling. But now its slipping it's time for a new one. What should I look for when I'm in there?? And what should I buy?? I need help, I have never done a clutch job before.. PLEASE HELP
Re: My 75' CB750F is in need of a clutch jod. What is the best???
« Reply #1 on: August 22, 2005, 05:18:23 AM »
You have to remove the friction plate that sits on the pressure plate and a steel plate in the middle of the clutch pack. Replace the steel plate you removed with the Goldwing plate.You will have the steel plate against the the aluminum pressure plate but it is OK as it turns with the pressure plate. It is a good idea to bead blast the steel plates and use Barnett clutch springs.  Use OEM friction plates and soak them in oil first.
qcextreme
« Reply #2 on: August 22, 2005, 11:23:45 AM »
So what year GoldWing plates to I need and what ones do I tell them, when I order them, Does anyone have a step by step for this
Offline joeb
« Reply #3 on: August 22, 2005, 01:53:14 PM »
You can use this for the directions.  http://www.salocal.com/sohc/tech/tech.htm
« Last Edit: August 22, 2005, 02:03:08 PM by joeb »
