Author Topic: Will it go into gear if clutch is out?  (Read 776 times)
Offline dramsell
« on: May 21, 2008, 06:36:15 PM »
Stupid question-I know!
But if I have the clutch out for replacing, will the gear shifter put it into gear?
Dave
Offline Bodi
Re: Will it go into gear if clutch is out?
« Reply #1 on: May 21, 2008, 07:00:26 PM »
Yes. The transmission is functionally separate from the clutch. You turn the sprocket (or the clutch output) to line up the dogs if it won't shift - the gears can be set in an impossible-to-shift position when not turning.
Offline dramsell
« Reply #2 on: May 21, 2008, 07:19:23 PM »
I only ask because in a previous post someone said I might not have a clutch problem (it would not go into gear) but a tranny problem.
The clutch is out of bike but it will roll freely while I push the shifter down and it is apparently in gear.
What the F?  If this is a tranny problem does this mean I have to tear motor apart?
Dave R
