Author Topic: Seat Lock for 72 CB750 - will this fit?  (Read 1896 times)
RichK2
« on: August 22, 2005, 03:55:55 PM »
My CB750 came without any trace of a seat lock. the seat can flap up at any time! Will a 73 one fit my bike?:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4569690703
Offline Jonesy
  • Shop Rat
Re: Seat Lock for 72 CB750 - will this fit?
« Reply #1 on: August 22, 2005, 04:08:26 PM »
This might be of help. It looks like it will fit, as the same type of lock was used on the K3 as well.
« Last Edit: August 22, 2005, 04:11:12 PM by jonesdp »
RichK2
« Reply #2 on: August 22, 2005, 04:17:34 PM »
thanks for that but the image only seems to refer to k1 / k2 - are you sure about the k3 being the same? thanks!
rich
Offline Jonesy
  • Shop Rat
« Reply #3 on: August 22, 2005, 04:18:23 PM »
I have a K3 and it looks exactly the same. I have the K0-K8 model comparator and it doesn't say anything about seat lock changes on the K3 model.
RichK2
« Reply #4 on: August 22, 2005, 04:48:54 PM »
ahh. thank you so much then i think i'll go for this one!
rich
Offline MikeDeB
« Reply #5 on: August 22, 2005, 05:53:49 PM »
The seat lock will work on the K2 because from 72 through 76 they were the same part number.  But the ignition switch in the auction has the square plug and K2s have the round plug so the ignition switch in the auction will not work with your bike.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline Jonesy
  • Shop Rat
« Reply #6 on: August 22, 2005, 06:02:37 PM »
Hmmmm... did they give a key # for the switch?
Offline MikeDeB
« Reply #7 on: August 22, 2005, 06:28:06 PM »
As long as it's a Honda OEM switch the key # will be stamped on the face of the switch (older ones) or on the side of the switch (newer ones).
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
80 SR500
Offline Jonesy
  • Shop Rat
« Reply #8 on: August 22, 2005, 07:46:56 PM »
If you want the correct key switch, check out this auction #: 4570646308
