Author Topic: 84/4 Interceptor 500cc  (Read 1267 times)
Offline snarferer
« on: May 25, 2008, 07:05:44 PM »
I would like to know what (potentially) might be wrong with this bike and can a home mechanic fix it without ripping his hair out, and/or spending lots of $$
http://philadelphia.craigslist.org/mcy/693774432.html
Any ideas?  I would laugh my ass off if the idle wasn't high enough...
okie
Re: 84/4 Interceptor 500cc
« Reply #1 on: May 25, 2008, 07:55:43 PM »
That bike had an electric fuel pump.  If it isn't working, maybe the thing runs off of the fuel in the carbs, then quits.????
Offline DarkRider
« Reply #2 on: May 26, 2008, 07:10:20 AM »
Either a bad pump or someone forgot to put the thing in during the frame swap.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
« Reply #3 on: May 27, 2008, 09:48:25 AM »
I believe the 84/85 had the electric pump, but Honda dropped it in the final 86 year.  I've owned two 86's and I believe that you could eliminate the pump on the earlier models, but not absolutely sure.  Certainly if you have a full tank of fuel, it should run, pump or not.  Another easy-fix problem was the vacuum petcocks which would leak air and stop working.
But.... this bike could be a money pit and the VF500's are EXTREMELY hard bikes to work on with limited and/or expensive spares.  The carbs are very finicky and very hard to work on - likewise the rear exhaust is a huge problem to get to.  VF's also have the cam-oiling issues and the forked-rocker problem, although the 500 seems much less afflicted then the 700/750.  Final thing is that the 84 500's were subject to a crankshaft recall - most were fixed by Honda early on, but you would need to confirm this.
Very neat bikes (probably the best-handling machine of this genre and still a wonderful handler today) and a great little jewel of an engine.  But not a good candidate for the novice home mechanic looking for a fixxer-upper.  This looks like a $300 bike to me that you take home, do a few things to see if you can get it running, but probably punt and part out on Ebay and make a few bucks.  (I'd view the owner's claim that he paid $1K for a non-runner on Ebay skeptically - if he did, he's a fool.  Maybe five years ago, I sold both mine in near mint condition for $1500 each and I don't think they've gone up in value very much.)
- Mark
« Last Edit: May 27, 2008, 09:52:28 AM by markjenn »
Offline DarkRider
« Reply #4 on: May 27, 2008, 12:29:23 PM »
I know you can convert the larger 700/750/1000 to gravity feed to dump the pump. There is a how to for converting the Vac petcock to non vac operation..
http://www.daughertymotorsports.com/  Click on How tos..then click on VF500 Tank Valve modification.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline snarferer
« Reply #5 on: May 27, 2008, 07:16:13 PM »
Yeah I am an extremely amateur (read slightly inept) home mechanic....I'll steer clear of this one, but I'd love a bike like that.
Offline DarkRider
« Reply #6 on: May 28, 2008, 02:29:16 AM »
If this is to be one of your first bikes you would be better off finding a better example of the breed. They can be had for cheep..but as said...better off finding one thats already running.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
okie
« Reply #7 on: May 28, 2008, 04:21:54 AM »
Dark Rider has it right.  This (VF500F) is NOT the bike to learn motorcycle mechanics on.  Nothing about the bike is typical of bikes in general.  If you stick with a SOHC Honda you will have this forum as a resource.  Nothing can go wrong with a good old SOHC that someone here hasn't already encountered and fixed.  Unlike the SOHC bikes,  the VF500 is practically impossible to bring back from the dead.
Offline snarferer
« Reply #8 on: May 28, 2008, 08:25:43 AM »
I have a 350F that I've done a small bit of wrenching on, but I'm always looking to add a cheap second bike to the stable.
