Author Topic: 75 cl360 float height  (Read 2096 times)
Offline parm
« on: May 27, 2008, 10:06:40 PM »
i just rebuilt my carbs today, im at the point of setting the float height. does anyone know what it is suppose to be? in the manual it says 18.5mm. but im just double checking to make sure there isnt a better height to set it at. anyhelp would be awesome thanks!
Chad
Re: 75 cl360 float height
« Reply #1 on: May 28, 2008, 10:42:32 AM »
Here is a screenshot from a PDF I have.
Offline cb650
« Reply #2 on: May 28, 2008, 04:20:35 PM »
Thats what my chiltons says also.    Has the cam chain adjuster been upgraded?
« Last Edit: May 28, 2008, 04:22:06 PM by cb650 »
Chad
« Reply #3 on: May 28, 2008, 04:22:14 PM »
Mine hasn't  >:(
I am searching for information on that recall. In the meantime, I'm adjusting the cam chain  tensioner every 1000 miles or so.
Offline cb650
« Reply #4 on: May 28, 2008, 04:25:20 PM »
What was the problem?    A part failure or just fast wearing?
Chad
« Reply #5 on: May 28, 2008, 04:28:47 PM »
Here is the best description I found of the recall:
"The cam follower rocker shaft was originally a two piece design and it was replaced with one piece design.  If you pull the plug out of the cylinderhead top cover that covers the rocker shaft and the plug has an integral shaft, it's been updated.  The earlier designs wore out the bore for the rocker shaft because the shaft would spin in the bore."
http://en.allexperts.com/q/Motorcycle-Repair-837/2008/5/1975-Honda-cb360-1.htm
Offline cb650
« Reply #6 on: May 28, 2008, 04:43:04 PM »
Cool explanation.   Never did know what the prob was.  BTW Chad that bike is a ugly color ;D.
Chad
« Reply #7 on: May 28, 2008, 04:44:21 PM »
 :o
Whoa!
Folks are always talking trash about the CB360, and now the color, too!!
You got any suggestions to clean it up??
Offline cb650
« Reply #8 on: May 28, 2008, 04:50:41 PM »
Yea paint it like mine ;D.  Have a couple pics of it in my gallery.
http://gallery.sohc4.net/main.php?g2_itemId=3040
