Author Topic: CB750k4  (Read 691 times)
Offline grajaguar
CB750k4
« on: May 28, 2008, 10:05:23 AM »
how do I sync. the 4 slides on my carbs. fact #2 is fixed cannot move right? do I adjust 1,3,4. to the same height as #2.?   I notice #2 is a bit higher than the other 3 the bike is 74, cb750  4,800 miles just bought it , first time its run since 1986 ???  thanks, Graham
Re: CB750k4
« Reply #1 on: May 28, 2008, 11:16:31 AM »
You attach vacuum gauges to the intake ports and adjust the slide height till the vacuum gauges read the same.
The newer PD carbs don't have adjustments on #2.  But, the earlier ones should.  ... I think..
Offline Borkunit
Re: CB750k4
« Reply #2 on: May 28, 2008, 12:13:44 PM »
My K4 is adjustable on all 4 carbs (assuming that I have the original carbs).
Offline grajaguar
Re: CB750k4
« Reply #3 on: May 28, 2008, 01:41:50 PM »
i did'nt want to force #2 to loosen , maybe a liittle heat on the thread lock will do it. yes the carbs are original. thanks for your input, has any one else had to apply heat to the thread lock?
« Last Edit: May 29, 2008, 07:41:46 AM by grajaguar »
Offline hopterfixer
    • My flickr Gallery->
Re: CB750k4
« Reply #4 on: May 28, 2008, 02:55:37 PM »
All four carbs will adjust.  Put some penetrant/lubricant on the nuts, let it sit, and use six point box end wrenches to break it loose.  Good Luck.
Offline grajaguar
Re: CB750k4
« Reply #5 on: May 29, 2008, 03:48:10 PM »
 Thank you everyone,   #2 adjustment nut is loose, problem solved.now I can get on with synchronizing   the carbs.
