Author Topic: accel 8.8mm stainless wires w/dyna ignition; will this work?  (Read 1388 times)
Offline zoo mob
I was just getting to installing my new dyna coils and ignition, the accel 8.8 stainless core wires I was planning on using have a warning not to use them or "any other metal core ignition wire set on 1980 or later Harley Davidson v-twins as radio frequency interference from metal core wires may cause damage to the electronic ignition module" is this applicable to a 73 750 k3? Do I need to worry about this at all? Thanks in advance.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Re: accel 8.8mm stainless wires w/dyna ignition; will this work?
« Reply #1 on: May 29, 2008, 07:55:57 PM »
No. You may have to grind the outer wire(s) a bit to fit into the coil outputs.
Offline zoo mob
« Reply #2 on: May 29, 2008, 07:59:15 PM »
Do I need 8mm wires? Also, worried about frying the ignition, forgive my ignorance, but is this an issue?
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
fuzzybutt
« Reply #3 on: May 29, 2008, 09:01:26 PM »
i use the 7mm copper core dynatek wires, they flow all the juice that ignition will put out
Offline chrislib
« Reply #4 on: May 30, 2008, 06:48:18 AM »
I was using Accell wires & coils on my 73 with an old Martek elec ignition. I never had any issues with it.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
« Reply #5 on: May 30, 2008, 07:21:53 AM »
 Solid wires would only be a problem with the Dyna 2000
