Perhaps these are different seals, but all the ones I've installed had an open side and a closed side and you could see a small coil spring going all around in the open side. The open side faces the oil, the closed side faces the outside world. If there's no open side, the sealing lips should have a saw tooth shape that scrapes oil one way, this should scrape oil back into the fork.
