Author Topic: would you replace the gas lines if rust was present  (Read 665 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: May 30, 2008, 09:33:54 AM »
not sure if this is important or not....should I replace the lines from petcock to inline filter and down to the carbs. present in the tank.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline mystic_1
  • 1970 CB750K
Re: would you replace the gas lines if rust was present
« Reply #1 on: May 30, 2008, 10:06:25 AM »
Fuel line is cheap, and cleaning carbs is a PITA.  Replace them if it increases your peace-of-mind, but probably not strictly necessary if cleaned.  Has the source of the rust been eliminated?
mystic_1
- John Augustus Shedd
asianq
« Reply #2 on: May 30, 2008, 03:47:14 PM »
I agree. Few bucks for lines prior to inline filters. If filters look ok, I wouldn't worry about them.
Good luck.
