Step 1 - Check the head pipes for even temperature.
Step 2 - A complete and thorough tune-up, like what is outlined in the owners manual for 3000 mile intervals, including a new air filter and carb balance.
Step 3 - If you have stock exhaust, set the carbs to factory adjust specs with the factory parts. (#98 mains, needles with stock profile in 2nd groove, # 38 slows, Idle screws set at 1 1/2 turns.) Making sure the emulsion tubes are clean and the float height is correct @ 22 mm.
