Author Topic: Oil Leak Locations  (Read 5788 times)
Boogerbandit04
Oil Leak Locations
« on: June 02, 2008, 05:02:48 PM »
Battery problem fixed, just not enough riding above the right RPM. I now noticed I am leaking oil from what looks like where the gear shift lever meets the side of the engine. Is there an oil seal there that could have gone bad? There is also oil along the cooling fins, O-Ring?
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Oil Leak Locations
« Reply #1 on: June 02, 2008, 05:21:02 PM »
Yes.
O-rings....they all do that, mate! Live with it or take the top end off and replace them.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline neudl
« Reply #2 on: June 02, 2008, 05:28:15 PM »
It's the shift shaft seal.  Takes about 5 min. to replace. Instructions on numerous threads.
Boogerbandit04
« Reply #3 on: June 02, 2008, 06:04:21 PM »
Shift seal eh? Im looking on Honda parts direct, is part #22 the right seal? Im just  wondering. Im still new to all this stuff, I have a repair and maintanince manual but its not very clear.
http://www.hondaparts-direct.com/fiche_section_detail.asp
Offline neudl
« Reply #4 on: June 03, 2008, 09:03:39 AM »
91202-KFL-841 is the part no. for a CB550 (1976). Probably the same part for other years.  I could not get you link to open the schmatic, but it is part no 22 in the "gearshift drum" schematic.
Offline Hope
  • How did I become an
  • SOHC member since '01
« Reply #5 on: June 03, 2008, 02:28:35 PM »
Offline Johnie
« Reply #6 on: June 03, 2008, 03:53:24 PM »
Easy change out for you.  You will be glad you did it too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #7 on: June 03, 2008, 04:47:52 PM »
How much of a booger is it to change the Tach drive seal. It appears I am springing a minor leak. I am at the wipe it off mode right now, but I am sure it will not cure itself.
Offline Johnie
« Reply #8 on: June 03, 2008, 08:04:37 PM »
Hey right Bobby...those don't cure on their own. ;D  Seriously, it is an easy fix for you.  I saw a thread on Tips and Tricks that might help you out too.  Heck, the seal is like a dime with a hole in it.  If you use the screw method, do not drive that screw between the center hole of the seal and the shaft or you will score the shaft and have a leak forever.  Some guys drive the small screw right into the seal and pull it out.  For ease of putting it back in, I use a dummy tach housing (see pic) and push it right back in.
Oshkosh, WI  USA
