SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Mnting 2nd Frnt Caliper, Possible fork switch for behind tube caliper placing???
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Mnting 2nd Frnt Caliper, Possible fork switch for behind tube caliper placing??? (Read 1349 times)
Greenbush
Guest
on:
August 25, 2005, 03:23:57 PM »
I was wondering if anyone has tried this. I have bought a second caliper set-up to give me double up front on my 76 750K. I am okay with doing this. ****Here is my question; If I were to switch my forks to the opposite sides and then rotate tubes so the mounting brackets are facing the rear, can I safely mount my calipers in that position.
I know that a big part of the reason that our early CBs have weak stopping (front) power is because the calipers sit on the front of the fork tubes trying to stop the rotor as it moves away from the caliper. Has anyone tried this or know anything about this possible alteration?
Logged
Bob Wessner
"Carbs Suck!"
Really Old Timer ...
Re: Mnting 2nd Frnt Caliper, Possible fork switch for behind tube caliper placing???
Reply #1 on:
August 25, 2005, 04:21:41 PM »
See this thread, sounds like someone has done it so if you have questions...
http://www.sohc4.us/forums/index.php?topic=2579.0
Logged
kyre
Hot Shot
Reply #2 on:
August 25, 2005, 04:58:05 PM »
I've done it. works good. if you want to use the original front fender then you'll have to drill the rivets out and rotate the bracket then rivet back in.
Logged
CB400F / 466 Build Thread (currently in progress)
http://forums.sohc4.net/index.php?topic=105027.0
Buffo
Guest
Reply #3 on:
August 25, 2005, 05:07:20 PM »
did you run into problems bleeding the calipers due to the nipple not being at the highest VETICAL point???
Don
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
