SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Project Shop
Topic:
Center stand vs. chain
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Center stand vs. chain (Read 2415 times)
AK Cafe
Guest
on:
June 03, 2008, 08:09:19 PM »
Hello all, tonight I decided to mount up a center stand that I bought off of ebay on to my 550. The installation went well but after I hooked up the spring I found that it holds the stand up against the chain all the time. Any suggestions?
AK Cafe
Logged
Badger 5
Hot Shot
Re: Center stand vs. chain
Reply #1 on:
June 03, 2008, 08:14:35 PM »
A buddy of mine had the same problem. He put a u-bolt on the exhaust mount on the other side to keep the chain down. Also, Benjie makes a great center stand stop that I'm sure he would sell separately if you email him.
http://www.benjiescaferacer.com/
Logged
76 CB550K
75 CB200T
68 CL160 (AHRMA R78)
07 Triumph Bonneville Black
75 XS650
Shenanigans
At making holes in walls, Im a
Master
Right turn?
Reply #2 on:
June 03, 2008, 08:17:40 PM »
I'm pretty sure that the center stand is stopped by a pad on the bottom of one of the stock pipes. Seeing as you don't have stock pipes you might have to make some sort of stopper.
I never thought about that happening. If its true its good to know for future reference.
Logged
This pretty much sums it up. 76' CB592 cafe. 69 750 project, 03 CBR954, 75 750 super sport.
mrbreeze
Not your average
Really Old Timer ...
Shut up when you're talkin' to me!!
Reply #3 on:
June 03, 2008, 08:34:25 PM »
yep......its true!!! When you ditch your stock 4 pipe exhaust and go 4 to 1....you have to make a bracket to bolt to the right passenger peg hole. Adjust it to hold the center stand below where it contacts the chain. I still haven't came up with a permanent mount for my Kerker but I did take care of the centerstand hitting the chain.
Logged
MEMBER # 257
SohcCBs
Enthusiast
76 CB836F 77 GL1000
Reply #4 on:
June 03, 2008, 08:44:50 PM »
The Supersport has a metal bracket that mounts between the rear peg bolt and the rear brake calipar to hold the centerstand lower than the chain. You might be able to modify one, or make something along those lines.
Logged
http://www.SohcCBs.com
Tech Site Back
AK Cafe
Guest
Reply #5 on:
June 04, 2008, 12:51:51 AM »
Thanks for all the tips. I fabricated a 90' angle bracket and bolted it to the RH mount for a temporary fix. It holds the stand down enough to ride but it's not a permanent fix. When I tear it down this winter I will find a more permanent solution.
AK Cafe
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Project Shop
Topic:
