WFO: None of this is meant in offense. NONE OF IT. If you accept this, then read on.
For your own good, I’m going to use your own words against you. First you said:
“... the bike runs like a dream and i pulled the plugs looking for any abnormalities. The plugs all look great …”
Then you said:
“… I am bumping this cause i really would like more opinions on the pilot screw positions they are all different and it looks like the last person to mess with them filed off the stops so he could adjust them which would lead me to believe they are not adjusted correctly … “
You are lead to believe from their APPEARANCE that they are not adjusted correctly, yet the bike (the most important witness) gives you the very real testimony that it, to quote you, “…runs like a dream …”
Then you said:
“Ok i hear what your saying and i completely understand but let me re explain my concern, when one adjusts the pilots and dials em in they glue limiters on the screw head to keep them from turning counterclockwise so they all should be point in one general direction IMO …”
There are three possible smart actions on your part:
1) Re-adjust them so the bike runs like a dream. Oh! Wait! It already does! Then maybe you should leave them alone.
2) Leave them alone. This, the fact that they are all pointed different directions even though the bike runs perfectly, will drive you nuts. (Did you ever consider that the manufacturing tolerances and idiosyncrasies of an assemblage of hundreds of parts – not just in the carbs, but in the whole engine – require these slight variances in adjustment, meaning they are adjusted properly, just not identically?) So …
3) From my past experience. (This will be a little vague because it was 30 years ago and I was never an audiophile.) My father was an engineer. A couple of knobs on different pieces of his new stereo didn’t align even though the performance and meters said they should. It was making him, an engineer, NUTS. So I told him to go make some coffee for us while I looked at the internals of the units. When he came back with the coffee, the knobs were aligned. He asked how I did it, I said, “I’m not completely sure, but I started turning screws inside the back and the readings changed and I think I got them right….”
You guessed it. I took the knob off and loosened the nut holding whatever it was inside, rotated the threaded stem 10 degrees, retightened the nut and put the knob – now perfectly aligned with its mate – back on. He was happy with that stereo for decades.
So, go buy four more limiter caps and glue them on so they are aligned.
Listen to your bike. It speaks the truth …
