Author Topic: vibrating turn signal indicator?  (Read 4462 times)
vrrvroom
« on: June 06, 2008, 08:26:40 AM »
i need to put an end to the horrible squawking sound of the turn signal buzzer on my cb750.  it's hard to love everything about something but absolute despise just one thing.  i've read up on some pretty neat workarounds for it.  the obvious: disconnect, and the ingenious: have it switched on only when the brakes are engaged.
so here's an idea, wondering if anyone's tried this, how it's worked out.  get 1 or 2 pancake style vibration motors, like this: http://www.sparkfun.com/commerce/product_info.php?products_id=8449.  hook it into the turn signal wiring, and tuck it in under your grips or anywhere on your handlebars.  these are the motors that they use in pagers and cell phones, pretty strong, so i'm thinking it should do just fine, ie - be felt over the vibration of the road, running motor.
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
Re: vibrating turn signal indicator?
« Reply #1 on: June 06, 2008, 08:30:55 AM »
Great idea...turn-on vibrator...need I say more?
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: June 06, 2008, 11:23:03 AM »
- John Augustus Shedd
« Reply #3 on: June 06, 2008, 11:36:48 AM »
Slight correction, have it switched on only when the brakes are DIS-engaged.  That way while stopped it is silent, but still a reminder to all that it is signaling when getting under way.
My opinion, vibration is the enemy of electrical switches.  And, the bike already puts enough vibration into my hands.  Further, the one you've pointed to runs at 3V.  Bike has a 12V system.  Probably vibrate a LOT for a short while!
Offline bradweingartner
  • 74 CB 550 x2
« Reply #4 on: June 06, 2008, 04:56:35 PM »
I kinda like the idea.
Finding a 12v motor that fits nicely into the handle bar is easy enough. Adding a counterweight to that motor is also easy enough.
If it is noticeable enough over the other engine vibrations (which I question) then it shouldn't be on for much time at all really and isn't going to hurt switches or wear too much on the motor bushings.
My thought was to add a blindingly bright LED in place of the stock dim incandecant bulb. Even on a sunny days bright LEDs should stick out.
Offline Jonesy
  • Shop Rat
« Reply #5 on: June 06, 2008, 05:05:40 PM »
I thought I read somewhere there is a unit engineered specifically for motorcycles to make the seat buzz with the turn signals (OK.. no requisite dirty jokes now...  ;D).
It could also be wired into the oil pressure light to get your attention a bit quicker...
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: June 06, 2008, 05:44:03 PM »
There is Jonsey, follow the link I posted above. :)
mystic_1
Offline Jonesy
  • Shop Rat
« Reply #7 on: June 06, 2008, 06:04:45 PM »
Maybe that was where I read about it before...  ;)
Sorry. :-[ :P
