Author Topic: How similar are the CB500 and CB550 four cylinder bikes  (Read 1818 times)
Offline johnzmg
« on: June 08, 2008, 05:06:50 PM »
I have a '71 CB500 K0 project bike that needs a few parts. How similar is a CB550... do most parts interchange?
Thanks!
John
Re: How similar are the CB500 and CB550 four cylinder bikes
« Reply #1 on: June 08, 2008, 05:17:41 PM »
The most similar is the 74 CB550 and the least similar is the 78 CB550.  Parts interchange becomes worse as the models change.  To ask for a complete list of interchangeable parts is a tall order.  You are asking about 10 different bikes including your own. Better to ask about specific parts.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: June 08, 2008, 05:41:39 PM »
       Yeah, it would help to know which parts you are talking. There were several changes made during the run of those and it takes some different external parts for some of them. pretty detailed and would take up quite a bit of time and effort to list everything. We're all glad to help where ever but, need things narrowed down a bit.
Member # 1969
Offline johnzmg
« Reply #3 on: June 08, 2008, 07:23:39 PM »
I was hoping the 550 was a bored out 500. It makes sense the later CB550s would be the most different. I haven't taken time to make a list of the neded items. Most of the parts I was hoping to interchange are for the "body" and chrome.
Thanks!
John
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #4 on: June 08, 2008, 08:12:59 PM »
Cross reference here:  http://www.cmsnl.com
You have to register.  Search the fiche for your bike to find the part numbers you're looking for.  Search by part number will give you your cross reference of other bikes that part was used on.
1977 CB750
Offline hymodyne
« Reply #5 on: June 09, 2008, 10:57:20 AM »
the CD rom version of the honda 500 manual has has an appendix that lists the changes between the 500 and 550 K models.
hym
"All things are ready if our minds be so."
Offline rachet
  • '77 CB750 F2
« Reply #6 on: June 09, 2008, 11:32:31 AM »
I have a 71 cb500 and a 75 cb550.  the Carbs on the 550 overflow on number 3 (at least that's what the PO said) so I was thinking about rebuilding the 500's carbs (the bike is completely pulled apart) and dropping on the 550.  That's compatible enough yea?
But I need Tacos!  I need them or I will explode!
« Reply #7 on: June 09, 2008, 12:03:14 PM »
The carb bodies are the same and will interchange.  The internal set up of the carbs and some of the internal carb parts are different, to accommodate the displacement change.  The carbs will "work" the bike.  They won't be tuned correctly.
Of course, if the air filter and exhaust are changed from stock, then you'll have to tune either set of carbs to the changes made.
The carbs have an external stamping to identify the internal configuration.  However, POs seldom alter those markings after changing those internal parts/settings.  Then the only way to tell what you have is dismantle and measure.
Offline rachet
  • '77 CB750 F2
« Reply #8 on: June 11, 2008, 02:20:04 PM »
Thanks TT!
I would love to have half of your knowledge about these bikes!
Rachet~
