Author Topic: Stripping 750F Black engine?  (Read 1719 times)
Offline zeus87
« on: June 10, 2008, 03:19:57 PM »
Looking into stripping the paint off my factory F engine...any suggestions?  Anything besides walnut or plastic blasting?  Thanks
Offline scondon
  • Mmmm......tasty bugs
Re: Stripping 750F Black engine?
« Reply #1 on: June 10, 2008, 04:21:48 PM »
  If you're going to paint it black again just rough sand and smooth down no further than factory primer. Nothing in a can sticks better than it and your paint will last a lot longer, especially in wear areas like the shifter cover.
   If you want to make it shiny aluminum, well, I don't have a clue. I like my motors just like my oil....er, black!
Offline Magpie
« Reply #2 on: June 10, 2008, 05:37:00 PM »
A spray can of Aircraft Aluminium Paint Stripper/remover will do it. Nasty stuff though, be very careful with it. Spray on, brush a bit and hose off. I got some at the local auto parts store.
Careful with it!
Cliff.
Offline zeus87
« Reply #3 on: June 18, 2008, 10:01:56 PM »
hmmm, i dont want to get stuck with intentions that didnt come out right....Anway, how about repainting the block and then polishing the head and covers?  i like the look, but whats the best way to prep the engine for a second layer of paint? should i paint over the top just after cleaning and degreasing?  Also will the aircraft stripper eat my gaskets? THANKS!
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
« Reply #4 on: June 18, 2008, 11:02:16 PM »
Anything that is not metal should probably steer clear of the Aircraft Remover. It will definitely eat through everything, and make the job a lot easier for you, but it the aspect of gaskets, rubber, plastics, anything other than metal needs to again STEER CLEAR of that stuff..
I don't want to scare you away from using it, I used it to clean up my engine before polishing, and painting the fins. In fact while the engine was out, I sprayed the whole thing down and let it sit  a while and do it's thing, but still avoiding contact of wires, and what not that is around the engine..
good luck
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline zeus87
« Reply #5 on: June 19, 2008, 08:21:10 AM »
very good, yeah i have the engine out...i just wanted to make sure it isnt going to eat into the head gasket etc..
