morning,
After replacing a disintegrated intake valve spring with a spare I now have four cylinders firing on my 500/4!
While riding, I noticed that there was some hesitation and a lack of quick response to my throttle commands. The bike accelerates quickly through gears 1-3, with rpms topping out about 6-7k. In the Higher gears, the engine bogs and searches, revving more cleanly only after I back off the throttle slightly. A mechanic suggested that the engine sounds like its running lean, so I'm adjusting the clip setting on the main needle (the long one inside the plunger in each throttle body). As I posted a couple of months ago, the bike has carbs from a 550 on it, and since then I've replaced the head which was full of stuck valves with a spare from a '76 550 as well. I've ditched the pods and gone back to the stock airbox, but I still have a 4-1 system with a Keag canister.
now, I only have one notch left for adjustment of my main needle available to increase the flow of fuel.
I'm going to make the adjustment and see how it runs. If this doesn't do it, what are my options? How do you select new Needles? these needles are numbered D26. what others can be bought for these carbs?
hym
