I just got a set of rings off ebay for my 76 CB750k, the box is marked MC so not sure who actually manufactured them, but anyway. The original rings used a 3 peice oil ring, this new set of rings came with a one peice oil ring. My question is, what should I set the gap at on the oil ring? I've searched on here for a while and only found specs on the compression rings. The ones I got were tight, at .008, so I set those to .016, I haven't touched the oil ring yet, but I check the gap and it was .008. Also should note this a std. bore. One more question about the one peice oil ring, does it matter where I put the gap of the little spring type ring that fits behind the oil ring, I figured it will move around anyway, but didn't know if there is a specific way to install it. Thanks alot for any help
