Author Topic: Master Cylinder Question: Old Style W/Screw-on Cap vs The Later Ones.  (Read 999 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
      Thing is, I've got the 80' CB750K that had a master cylinder like the SOHC4 750 (and various others) on it, instead of the one that was made for it. I want to know, if one is better than the other? I actually like the fact that the older one has only the seals to be concerned about, whereas the later model one has the resevour that can deteriorate as well as the seals. I have one like the one that was meant for it but will need a rebuild kit as well as a new resevoir and I have the type with the screw on cap. Just like to know what others think, as far as which one is better or if either is better. ;) Thanks
Member # 1969
Offline tbpmusic
Bill -
Info I've gathered, dealing with these things.
The old screw-cap is probably for a single-disc model, with a piston diameter of 12.7 mm.
Newer ones are for dual disc models, and have a 14mm piston.
Which to use??  Your call. Use of the dual-disc models on a single disc may result in a LOT of force down at the caliper - maybe it will work nicely, though.
bill2
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline bill440cars
        Hey Bill. :)  This is the one that should be on it (and it's only got a single disc).
        And this is what's on it presently.
        May go ahead and use the old style. I just want to make sure it works good enough. Trying to use what I've got, ya know?
                       Thanks for your reply on that,  Bill
Member # 1969
Offline TomC
hi tbpmusic
     I have small, medium, & large SOHC4s. I have a pile of screw-cap master cylinders. All of them are 14mm bore. Can you or anyone else tell my what the 12.7mm bore master cylinders actually fit?
          TomC in Ohio
Bill -
bill2
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
