Cold out today, getting the tailend of that storm that hit Mnpls StPaul. Not so much accumulation but cold and blowing. 20 outside, 55 F in the shop. For those of you lacking heat in your shop, a tip. Get one of those shop light stands that has 2 500w bulbs in it. You need the light and they put out a lot of heat as well.
I wanted to do some sodablasting on the shift drum and forks, but didn't get it done. So no engine work. But on the first break in the weather I'll blast those parts and we can button up the bottom end. We are leaning towards putting the bottom end in the frame sans cylinder/head. Its been a long time since I've wrestled one of those engines around, and even though there are 2 of us, I think it will be easier to install the top end in the frame. But will check our deck and valve clearances on the bench in a dry mockup.
There's been a few things I've read about doing and never tried. Growing up in Honda shops, we were always told the instruments were unserviceable. It wasn't uncommon for CB750 instruments to get moisture inside and mess up the faces in the first year of life and we would warranty them often. Imagine my surprise when I first learned some years ago that people were cracking them and replacing the faces. I think I first heard of it on Carpy's site, and since I've read everything I could and thought it was magic. So today, I cracked into a used K2 gauge, using the paint can opener method. I won't repeat much here as its been covered so well by so many. I can say that cutting the ring and JB Welding it back together never appealed to me. So the paint can lid opener method really appealed.
So after taking off the obvious, start here:
Get aggressive with the can opener, progress up to a screwdriver:Then move up to a screwdriver
Then the ring will pull away
With the ring off, the black housing just falls off. Then pry the needle off with a kitchen fork, using the head of the faceplate screw to pry on
And success!
While i was doing this (took me 2 hours. Way too long, but i was really sqeamish about damaging the ring. Now that i know how, its probably more like a 20 mintue job.) Bruce was workiong on the sidecover. Bot from Joe Frankenstuff, they really fit good. But it hits my gusset, special case. I had Joe take some material off for me, but it wasn't enough. So he told me how to do it and using a nail file the material came off readily. Its very soft and thick and workable.
No fit:
Business card fit (Furious George's card. May be my painter)
Final clearance, can't tell it's been worked on, love this material, much niver than brittle old ABS:
Bruce worked on the emblem pockets. They weren't quite right, and I'm afraid with some thick paint they will scrape upon install. Easy to relieve them though. Hand held Dremel tool bits cut the material easily for a perfect fit.
interference
working
perfect fit
Brake line routing doesn't suit me. The down hose curves back too much. With some compression on the forks, there will be too much free line. I'm going to reroute so the line runs parallel to the over fender line, and curves into the lower triple comfortably.
Drove all over creation (long story) to find out there is an Earl's Performance store on gasoline Alley that has brakeline in DIY pieces. So I'll be heading there one day this week to get what i need.
Now, does anyone want to buy a pretty good shape K2 tach that's been disassembled? I'm going to practice on a few others before i do my final ones.
