Prep begins in earnest for Ohio Mile LSR, June 18 and 19. Got a room minutes from the track and my wife will come over for Saturday day and night. I'll go on Friday afternoon so I can be rested for Saturday and Sunday. Rider Rick and his crew will arrive under separate cover, with a few bikes of their own.
I don't really expect to be competitive for an LSR, I just want to see how fast she'll go.
So we pulled the carbs for rejetting, fiddled with the centerstand bracket which doesn't seem to want to cooperate. Switch out the final drive sprocket from a 17 to an 18, adjust and lube the chain, see if the MotionPro throttle tube I bot will replace the fitted quickthrottle we have now. Make a list of things to forget...
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
Maybe its due for some new sparkplugs, since it still has the startup plugs in it that went to the drags...
![Embarrassed :-[](http://forums.sohc4.net/Smileys/default/embarrassed.gif)
Dropped the oil for the umpteenth time. I probably have a record for the most oil changes is 165 miles. Both magnet plugs were clear of debris. The filter cover was clear of debris also, as was the filter. Very happy about that. I've been checking the tank level periodically and it will go for weeks between starting with no change. The oil pump fix kit from Elan really worked, no more wet sump.
Have to put in some extra shop hours to make sure its all ready.
