Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 1234890 times)
Re: Phaedrus: CB750 RestoMod - Update: 02/17/19 w/new pics.
« Reply #4425 on: April 19, 2019, 12:54:42 PM »
PS: The front balanced up with no weights! The rear took 1.5 oz.
Offline Tintop
Re: Phaedrus: CB750 RestoMod - Update: 4/19/19 w/new pics. later.
« Reply #4426 on: April 19, 2019, 05:12:56 PM »
Glad to hear things are still progressing Ron, spring is just around the corner.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline CBJoe
« Reply #4427 on: April 20, 2019, 08:57:35 AM »
Awesome Ron  8)  Couple more shake downs and we can get it to the Dyno.
Sadly my 750 will take a lot longer to get mobile  >:(  Refinishing my workshop is taking forever.
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #4428 on: April 29, 2019, 05:17:19 PM »
AS mentioned, I'm going from recent to not so recent:
New Avon tyres mounted up and balanced.
Here's my tool for holding the axle still whilst removing the axle nut:
We have to remove 1 caliper to get the front wheel off, and let out all the air, and English it just right. Luckily we don't have to break the hydraulic line, jus bungee the caliper up out of the way, and stuff a dbl fold of cardboard in the pads to keep them from closing.
We modified the truing stand by moving the stantions together. There wer 2 holes for a slight adjustment. But that's simply not enough to keep the wheel steady. So Joe drilled aother set.
The purple nuts are cool. But slightly taller than stock, so they look like they're not on all the way. Don't know if I can stand for that.
Job 1 will be to get the brakes working. It took a while but we discovered that when the wheel was at certain parts of its up and down arc, the brake actuation rod came into contact with my ubertrick centerstand stay. So, we need to move the over the the left side and give the rod room to breath.  That means new muffler mounts both left and right. I've got some other ideas, both functional and blingful. More later.
« Last Edit: April 29, 2019, 05:33:02 PM by MCRider »
Re: Phaedrus: CB750 RestoMod - Update: 4/29/19 w/new pics.
« Reply #4429 on: May 11, 2019, 10:51:36 AM »
Pic of purple titanium cprocket nuts with nulock. Should have been in the last post.
JOKER brake stay and actuator rod. I've got several joker pieces already (valve caps and oil pressure gauge/and attache) along with Frankensteins clear plastic points cover, and Saldana exhaust brackets with holes,continues the hole/dimple motif:
Polished aluminum. Needs some chrome.   ;)
Offline CBJoe
Re: Phaedrus: CB750 RestoMod - Update: 5/5/19 w/new pics.
« Reply #4430 on: May 12, 2019, 09:40:08 AM »
Some pics from today’s work and video to prove it’s still running.  Needs another shake down ride and then Dyno Time!
'65 CB77
'66 CM91 (C90'ish)
Re: Phaedrus: CB750 RestoMod - Update: 5/12/19 w/new pics & audio
« Reply #4431 on: May 13, 2019, 12:35:32 PM »
Thanks for the posts Joe! I'm liking those pipes. The peak of the "blips" registered about 5000 rpm. I'll bet they really sing above 6000. I'm a  member of the hard break in crowd. This engine only has about 15 miles on it. I'm ready to let someone (You) take it out and thrash it.
« Reply #4432 on: May 18, 2019, 01:03:11 PM »
we decided to eliminate a variable and move the centerstand stop to the left side at least for now. Don't want anything interfering with the brake controls. For a scab job it worked out pretty well. Too bad the picture doesn't show as well.
With that done, and a final of several finals bolt tightening and etc. Joe took it for a spin.
After a nerve wracking (my nerves, waiting for Joe to get back)  25 miles, he pulled back into the shop. No leaks! No smoke (well a little out of the breather)
Yay!
« Last Edit: May 18, 2019, 01:19:28 PM by MCRider »
Re: Phaedrus: CB750 RestoMod - Update: 5/18/19 w/new pics & audio
« Reply #4433 on: May 18, 2019, 01:19:44 PM »
Where's Joe?  ;)
Offline CBJoe
« Reply #4434 on: May 18, 2019, 04:24:48 PM »
Where's Joe?  ;)
I don’t matter Jerry...here’s the man
Bike pulled nice and hard...handled very well and very few issues on the extended shake down ride.
'65 CB77
'66 CM91 (C90'ish)
« Reply #4435 on: May 18, 2019, 05:51:11 PM »
It was your report i was looking for  ;) Progress? How does it compare to the hot rod at this point?
Offline CBJoe
« Reply #4436 on: May 18, 2019, 06:01:23 PM »
I’m afraid to say I can’t comment...I only rode the hot rod about 10 miles last year before taking it off road to fix starter clutch issue and then having to take the front end apart to replace steering bearing.  And the I decided to upgrade all the electrics....and then I got sucked into gutting and remodeling part of house
I’m really hoping to get it all back together and running in the next 2 months.  Just not enough time in the day
'65 CB77
'66 CM91 (C90'ish)
« Reply #4437 on: May 21, 2019, 03:03:16 AM »
Looks great Ron!! Love the look of those pipes and the video sounds good as well. Glad to hear you have the motor all sorted out and no smoke this time. Cant wait to see the Dyno!
Good luck
Andy
« Reply #4438 on: August 12, 2019, 01:16:38 PM »
I'm scheduled for a dyno run on the 17th, but a work obligation may get in the way. We're getting closer anyway.
Maybe some duplicates in this batch as it spans the last 4-6 weeks:
Joker Machine Brake rod and brake stay
The end sticks into the hole on the head of the axle, keeps it from spinning when tightening axle.
Thin stainless steel washers, Taller titanium sprocket nuts , finished in purple, with nylok inserts;
Modified pit posse truing/balancing stand
New tires. I didn't wear out a set, they just got too old to use  :(
Had the muffler hangers reworked, no pics.
Carry on!
Re: Phaedrus: CB750 RestoMod - Update: 8/11/19 w/new pics
« Reply #4439 on: August 12, 2019, 01:27:09 PM »
CBJoe working on classic cm91 top end.
« Reply #4440 on: August 12, 2019, 01:48:18 PM »
Muscling that CM91 back into frame must a been a treat compared to putting a CB motor back in...
Offline CBJoe
« Reply #4441 on: August 12, 2019, 07:02:45 PM »
Here’s the snapshot of the muffler brackets Ron.  All nice and clean.
'65 CB77
'66 CM91 (C90'ish)
« Reply #4442 on: August 12, 2019, 07:41:52 PM »
Very nicely polished muffler brackets with sweeping lines and speed holes.
« Reply #4443 on: August 15, 2019, 09:09:55 AM »
Thanks, the speed holes are particularly unique, useful, etc.
I'll get the whole bracket chromed over the window for added aerodynamics.  ;D
« Reply #4444 on: August 16, 2019, 04:47:04 AM »
 It's the 17th tomorrow....good luck on the dyno. It is a great tool for tuning. Had my CB out yesterday and it pulls like a freight train.......(a 1000cc's helps with that). ;D
« Reply #4445 on: August 16, 2019, 12:24:15 PM »
Strange that 1000cc pulls that much harder than 836cc.
I had my 1000cc a la JMR Billet block out yesterday too, Kebab run ;)
« Reply #4446 on: August 16, 2019, 03:17:29 PM »
PeWe probably depends upon  can and carbs to some extent.
« Reply #4447 on: August 24, 2019, 12:08:20 PM »
 No luck getting to the dyno?
Offline CBJoe
« Reply #4448 on: August 24, 2019, 03:05:39 PM »
Bad weather moved in so shop cancelled dynos for the day...something to do with water getting into the ventilation system.  I believe Ron's in process of reschedule.
'65 CB77
'66 CM91 (C90'ish)
« Reply #4449 on: August 25, 2019, 07:00:54 AM »
Thanks Joe. Yes, Mike, bad weather blew in and Ducati called me and cancelled. They say high winds blow water into their fooling ducts and they don't like to do it.
I was ready to go, but not too keen pulling it on an open trailer 5 miles in the POURING rain. So we rescheduled for the 24th, which was a big mistake as the 25th is my wife's birthday and she has reserved the 24th for some activities. Ducati resch for Sat, the 31st.
