Hino, once again you hit it out of the park! I should have that on my tank rather than the wolf's head!
![Cool 8)](http://forums.sohc4.net/Smileys/default/cool.gif)
Today's shop time very interesting. First did an oil change. Gotta admit, more grit in the oil filter cover than I would've liked. But little in the filter. Let's hope it was start up debris, a little plastic beads undoubtedly,
![Sad :(](http://forums.sohc4.net/Smileys/default/sad.gif)
While we're at it, there was a thread we discussed the washer in the oil filter that always gets lost. Here is why:
![](http://i313.photobucket.com/albums/ll384/rondison/Phaedrus/P7010001.jpg)
The silver looks for all the world like part of the cart. And as such, being stuck to the rubber grommet, it gets thrown out with the used cart.
But in reality, the silver is a washer that needs to be retained and used again. Not the end of the world, but I'll bet 1/2 of all CB750s have lost this washer and 99% of people that learn about it want it back.
![](http://i313.photobucket.com/albums/ll384/rondison/Phaedrus/P7010002.jpg)
So I've had this bad feeling that after all we've been through getting a tank to work, with a left side petcock, I'd realized that we hadn't really tested this one for its ability to hold gas. We had sent it out to be professionally treated and guaranteed it would hold gas. Still not first hand knowledge so here it is outdoors on the sawhorses with a gallon of gas in it.
![](http://i313.photobucket.com/albums/ll384/rondison/Phaedrus/P7010003.jpg)
Afrter an hour we were convinced. While waiting we put together the fuel line. From the carb to the tank, we needed a reducer, which I'd found some weeks ago at a hardware.
![](http://i313.photobucket.com/albums/ll384/rondison/Phaedrus/P7010004.jpg)
So we've got a short piece of clear coming out of the carb. We can clearly see fuel flowing.
![](http://i313.photobucket.com/albums/ll384/rondison/Phaedrus/P7010011.jpg)
Then the reducer, then clear braid to the pet cock.
Upon re start, alls working well, no fuel leaks, pressure jumps to nearly 80PSI! on the Joker gauge. Tach works fine, proof of sorts:
![](http://i313.photobucket.com/albums/ll384/rondison/Phaedrus/P7010008.jpg)
With the tank in place for the first time, I can say the valvetrain noise was quiet and pleasant.
Problems: May have an alternator cover leak. Not confirmed yet.
Had several rt front rocker box screws loose, causing a stealth leak and a big mess in the fins. may have it all cleaned up, leaks on floor may be residual from this. Or may be something worse.
![Angry >:(](http://forums.sohc4.net/Smileys/default/angry.gif)
The Henry Abe tappet covers continue to perplex. Why would anyone design a tappet cover that simply won't work with a stock tank, or a stock frame? Not so enamored now with legacy of HA. Besides having to sub OEM for the IN on 1 and 4, seemed 2 and 3 won't come off without hitting the frame tubes! If i didn't have an APE frame rail removal kit i'd be screwed right now. Can't get them off to adjust the valves!
I'm totally pissed, for something so simple. I'll use OEM for now and talk to joker about their offering which like all their stuff is way cool. May not be period but I may be over that now.
![](http://i313.photobucket.com/albums/ll384/rondison/Phaedrus/P7010007.jpg)
So shooting for vid and riding around July 4th.
