Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 878602 times)
Re: Phaedrus: CB750 RestoMod -Shop Update: 11/12/17 w/ New Vid & Sound
« Reply #4225 on: November 17, 2017, 03:20:39 PM »
Probably a stupid question Ron, but have you done a compression test? I'm wondering if you've got a valve not completely seating? Cheers, Terry. ;D
Offline CBJoe
« Reply #4226 on: November 17, 2017, 04:33:51 PM »
Terry....Mike doesn't want to hear that kind of blather ;D
Let me know when you are going to dig into it Ron...I actually have one of those IR Thermometers and would be happy to bring it over or let you borrow for a bit.  Haven't used it yet, but this would be a worthy first go :)
Cheers, Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #4227 on: November 17, 2017, 10:29:05 PM »
[/quote]
Ha ha, I'm sure it has nothing to do with Mike's work Joe, but it might be something as simple as an incorrectly adjusted valve.
If there's not enough lash when the engines hot it won't have much in the way of compression, so a quick compression check won't hurt? Easier than stripping Ron's carbs, for sure! Cheers, Terry. ;D
« Last Edit: November 19, 2017, 01:43:28 AM by Terry in Australia »
« Reply #4228 on: November 18, 2017, 06:29:57 AM »
It was a while ago, and they all clustered around 220 psi. We'll be checking that and valve lash and such before popping the carbs.
Online PeWe
« Reply #4229 on: November 18, 2017, 07:52:43 AM »
oh yeah, Air/Fuel ratio was lean at the bottom, but by about 3000 rpm, it was no higher than 12 nor lower than 11, which the Mikuni manual says should be all right. So at least I shouldn't hole any pistons. I'll get the low range re-jetted.
Check cruising speed A/F ratio on the dyno is my recommendation for a street bike. You will use yours on the street too?
I had too rich needles that was revealed on dyno when the dyno guy checked the cruising behavior which is most important on a street bike. Earlier dyno runs were mostly WOT to check max power and A/F ratio.
Slowly increased throttle from 2000-6000 rpm. A/F ratio below 12. I lowered the needles 1 step but it was still too rich when cruising around in normal speeds in city and country roads, stuttering followed by bangs at decelerations. I lowered the needles 1 step more and finally bike ran really nice and even. I got it verified on dyno too. (plugs look better!)
I had too lean at WOT on 2 carbs. Same I had adjusted the fuel level on by clear tube. I changed back to make all 4 to use same main jet sizes.
All above can be seen on 3 dyno runs: http://forums.sohc4.net/index.php/topic,147350.msg1953508.html#msg1953508
- Compression test show 220PSI? That's a lot! Without cam?
I measured my last rebuild and got 175PSI, cam DP315. I guess the overlap reduce some. My 836 had around 190 with Action Fourss SS-1 cam with less overlap.
I hope this will help you to find the perfect tuning!
« Reply #4230 on: November 18, 2017, 09:14:56 AM »
We had it running great last year, dynoed at 79 hp. Everything spot on.
Then I changed the pipe, and removed the carbs to send them to be cleaned but never did. Adjusted the float levels (may have been a mistake) and now it runs like this.
IT has the wimpiest cam WebCam makes, a 41.
I wanted to ride it but got sick and can't ride, so a friend runs it at the drag strip. No cruising.
It really pumps, don't it?  My first 888, pumped 240.
Re: Phaedrus: CB750 RestoMod -Shop Update: 12/3/17 Comp Test: Sigh
« Reply #4231 on: December 03, 2017, 09:22:29 AM »
Valve lash was spot on. Cam chain spot on. Ignition timing spot on.
Comp Test: #1 = 90; #2 = 150; #3 = 210; #4 = 220
Sigh.   >:(   :(
Offline CBJoe
« Reply #4232 on: December 03, 2017, 06:05:35 PM »
Sigh.   >:(   :(
Bummer  :o
'65 CB77
'66 CM91 (C90'ish)
« Reply #4233 on: December 03, 2017, 06:10:33 PM »
Did you notice a sudden decrease in power? Any top end noise? And I HATE to ask this - smoke? Frame kit? Put a real cam in it this time.....  ;)
Offline Tintop
« Reply #4234 on: December 04, 2017, 06:42:08 AM »
Ron, have you now done a leak down test to determine if it's valves or rings?
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #4235 on: December 04, 2017, 08:10:33 AM »
The Dyno run we did showed the loss in power. 49 now vs 79 last year. No noise, no smoke, Yes to frame kit, I'm ahead of you on the real cam.
« Reply #4236 on: December 04, 2017, 08:11:07 AM »
Sigh.   >:(   :(
Bummer  :o
Yup.
« Reply #4237 on: December 04, 2017, 08:12:24 AM »
Nope. It should be obvious once blowing it apart.
Offline Phoenix
« Reply #4238 on: December 04, 2017, 09:59:04 AM »
What do you think is causing the almost consistent rise from 1 to four?  60#, 60# then 10#.  Doesn't make sense.
Ed
ps. Are you still working the morning shifts?
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
« Reply #4239 on: December 04, 2017, 10:29:34 AM »
Ed
I don't know, Ed. I have to concentrate my limited powers to add or detract on what is knowable. In this case, I only know I have to take it apart.   :(
Yes, we are. 10-12N every Sunday. We missed a few lately as I was out of town, or sick. But, its a firm schedule.
« Reply #4240 on: December 04, 2017, 11:51:11 AM »
I would still do a leak down Ron before you disassemble it.
« Reply #4241 on: December 04, 2017, 03:36:02 PM »
Please leak it down while assembled.....it is a great diagnostic tool Ron. Please do it if you have the tool.
Offline CBJoe
« Reply #4242 on: December 04, 2017, 04:37:31 PM »
Hey Ron...I'm out of town until the 18th of Dec...but when I'm back I'm free to lend a hand..Just let me know  :)
'65 CB77
'66 CM91 (C90'ish)
Offline Tintop
« Reply #4243 on: December 04, 2017, 05:41:47 PM »
+1 it will tell you were the issue is - intake valve / exhaust valve / rings.  I borrowed the 'tool' from my local bike shop.  Easy to do..Youtube. ;)
77 CB550 Cafe build
« Reply #4244 on: December 06, 2017, 12:07:34 PM »
I don't have the tool, but I'm inclined to get one if you think its important. I don't understand what it will accomplish, or how, but I've learned things before, occasionally.   ;)
« Reply #4245 on: December 06, 2017, 12:23:03 PM »
Ron - a leak down test will test exactly that - leakage from your valves, piston rings and head gasket.
I've done it on motors that I've acquired with no known history.
As a general rule:
Leakage under 5% indicates engine in excellent condition.
Leakage up to 15% indicates engine in good condition.
Leakage above 15% indicates that engine components are worn.
My brother also does leak down tests on his SCAA race car motor so he will know when it is ready for a rebuild
« Reply #4246 on: December 06, 2017, 10:14:59 PM »
Sorry to hear it Ron, but I guess I was right in suggesting a compression test before you pulled your carbs, I'll be interested to see what's caused this issue, what pistons and rings are you running mate? I know how careful you are with your assembly, so I can't see how you could have busted a couple of rings in different cylinders during assembly, and it certainly hasn't done enough miles to wear them out, it's weird.......... All the best. ;D
« Reply #4247 on: December 07, 2017, 06:49:52 AM »
As a general rule:
But how does it tell the difference between valves, rings, or gasket?
« Reply #4248 on: December 07, 2017, 06:52:11 AM »
ARIAS pistons and I think they are Perfect Seal rings, sourced from Mike Rieck. Could have been me. But it sure ran good last year.
Offline Tintop
« Reply #4249 on: December 07, 2017, 07:21:06 AM »
As a general rule:
If intake valve you will hear air leaking back through the carb / exhaust valve back through the exhaust / rings through the crankcase breather.
77 CB550 Cafe build
