Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 1196908 times)
Re: Phaedrus: CB750 RestoMod - Update: New Pics: 7/22/18
« Reply #4350 on: September 10, 2018, 09:15:24 AM »
what kind of spider is that?
At least not a black widow or brown recluse...it is way too social to be the later, seeing how it wants you to walk into its web...wait...maybe it does...
Just a normal Orb Weaver/Garden Spider....havent seen one of these yellow ones at my house for years though.
Yeah like that. Eeech
Offline CBJoe
« Reply #4351 on: September 16, 2018, 10:00:38 AM »
Popped over to give Ron and Bruce a hand....Cylinders got installed.  The Oil Rings were a bugger to get into the sleeves on #1&4.  Then some hunting down of Cam Tower Studs that were playing hide and seek in the garage.
Cylinder Head next Sunday Right Ron?  See you then
BTW...I tossed that picture of the cam tower stud measurement for reference.  Smaller threaded end in Block and upper protrusion from the surface is about 45mm.
Joe
« Last Edit: September 16, 2018, 10:16:27 AM by CBJoe »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #4352 on: September 17, 2018, 07:46:02 AM »
Thanks for the update and help Joe. I do want to clarify that last picture is of a spare engine and NOT Phaedrus! That thing is yuckee.  :D
« Reply #4353 on: September 17, 2018, 09:20:05 AM »
Good news since the threads in head for cam tower stud look like soon giving up. A small radius of alu close to stud.
Offline CBJoe
Phaedrus: CB750 RestoMod - Update: New Pics: 9/16 /18
« Reply #4354 on: September 30, 2018, 09:59:22 AM »
I'm sure Ron will post an update later leading up to this point.....but first a TRIVIA question!
Whats wrong with this picture?   :o  ::)
« Last Edit: September 30, 2018, 10:01:12 AM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
Re: Phaedrus: CB750 RestoMod - Update: New Pics: 9/16 /18
« Reply #4355 on: September 30, 2018, 10:11:10 AM »
Those are the wrong bolts in the cam caps. Those bolts go across the center of the head
« Reply #4356 on: September 30, 2018, 11:03:33 AM »
My K0-K1 Fische calls for a 6x58 flange bolt with a 10mm head. They definitely have Philips heads on the printed page as well in the posted picture, though I don't think it matters. The fish lists them as NLA. Truly, as the K2 and later fisches I can find don't show the Philips head. So I must have some early bolts.
The Philip/10mm combo is used in the indexing bolts, but they are way shorter than the cam bearing bolts. My cam bearing bolts with the Philips head/hex head combo, turn in 8 full turns which is my rule of thumb for a bolt/screw being long enough or too long.
I wish I'd written down all of the incompatible details this build has uncovered between experience, shop manuals and parts fishies.  :(
« Last Edit: September 30, 2018, 11:16:01 AM by MCRider »
« Reply #4357 on: October 06, 2018, 01:12:34 PM »
No takers on Joe's trivia question? We put the cam and rockers in without putting in the 4 little orings under the cam bearings. That has been rectified and we hope to make headway tomorrow!  :D
That gave me the opportunity to fine tune my skills of passing the cam thru the mickey mouse ears of the cam sprocket and jumping the chain up on the sprocket.
« Last Edit: October 06, 2018, 01:15:27 PM by MCRider »
« Reply #4358 on: October 06, 2018, 04:12:09 PM »
 I have a head that's so early it only has two o rings. #85 or less I'm told.
« Reply #4359 on: October 06, 2018, 05:40:36 PM »
Have you got a pic Don? I've got an ancient Sandcast head for my '69 engine build, but I hadn't noticed how many O ring depressions there are? ;D
« Reply #4360 on: October 07, 2018, 05:52:40 PM »
Yes, that's an odd duck. Never heard of it. But wouldn't be the first time.
« Reply #4361 on: October 07, 2018, 06:19:58 PM »
Good Day: Cam, rockers in, dyno cover, trans cover, off. Big blue Moroso cam timing wheel on.
Discovered source of rubbish found in oil pan. Whatever I used for gasket glue last time I had the dyno cover off, it wasn't the right stuff. It squeezed out on the inside of the alt space, and bits and pieces of it broke off and found there way to the pan. No evidence of it anywhere else.
« Reply #4362 on: October 07, 2018, 09:25:53 PM »
Glad to hear of the progress Ron, keep at it...
David
P.S. recommend you take special notebook or make notes to jog your memory on the next assembly/build so you can capture those inconsistencies and put them in a FAQ on the site. Or sticky thread about engine builds that does not fall into oblivion in an archive somewhere inaccessible.
Offline CBJoe
« Reply #4363 on: October 08, 2018, 03:27:11 AM »
Hey Ron...I know we were searching through the binders for it, but I think the attached PDF for Degreeing the Cam from Megacycle is we were looking for.
'65 CB77
'66 CM91 (C90'ish)
« Reply #4364 on: October 08, 2018, 07:37:02 AM »
Oh Magoo, you've done it again! That is the instruction sheet I had in my memory, and will be very helpful. When Bruce and I did the 41, it took some iterations to get the technique down, then it went pretty smoothly.
re: Your PMs about pre drilled titanium hardware. What a Find! I'm going to be ordering fork leg nuts, sprocket nuts, and probably some other. Put together a list of stuff you may want. You'll get a real good price on it.  ;)
Offline CBJoe
Re: Phaedrus: CB750 RestoMod - Update: New Pics: 19/30/18
« Reply #4365 on: October 08, 2018, 03:52:28 PM »
Haha...it’s all about the BLING isn’t it
'65 CB77
'66 CM91 (C90'ish)
« Reply #4366 on: October 09, 2018, 10:26:37 AM »
You know it!   :D
« Reply #4367 on: October 09, 2018, 12:43:59 PM »
Ron, NO GASKET GOO DAMMIT!!! Unnecessary and will only bite you in the ass buddy!
« Reply #4368 on: October 09, 2018, 02:13:03 PM »
Yeah I know can't imagine what got into me.
Offline CBJoe
« Reply #4369 on: October 09, 2018, 04:20:40 PM »
Here’s some pics I snapped last Sunday of the progress Ron..also your lightened Rotor
'65 CB77
'66 CM91 (C90'ish)
« Reply #4370 on: October 10, 2018, 06:23:55 AM »
Thanks Joe. Your pictures have a depth to them that my camera doesn't get.
Here's that hardware link for others to enjoy:
 http://www.probolt-usa.com/titanium-sprocket-nut-m8-x-1-25mm-drilled-for-lockwire-4.html
« Reply #4371 on: October 15, 2018, 05:48:37 AM »
Made some headway, set the valve clearances. Read and re-read the instructions for degreeing the cam. I've only done it once and that was a few years ago.
« Reply #4372 on: October 15, 2018, 08:36:20 PM »
Tell us more about the Ti bolts please..
« Reply #4373 on: October 16, 2018, 06:08:02 AM »
CBJoe gave me the link, which is in the post of a few ago. I've never dealt with them. I've read up on their operation. They manufacture out of the UK, and ship out of somewhere in FL. They seem to be worldwide. The pricing is on each product description. Colors are more.
But they are crazy cool in that they are pre drilled for safety wire. All shapes and sizes. Hope to get my order in this week. They are evidently big on drilled sprocket nuts. But a nut is a nut and you get your size and pitch and order.
I've found places that drill bolts, but none other that drill nuts. I tried to drill a few with a small drill press and jig, and failed miserable. Bit breaks with the slightest pressure.
« Reply #4374 on: October 28, 2018, 03:45:43 PM »
Bruce and I were having trouble getting our head's wrapped around the cam degreeing process. We'ld done it years ago with a 41 grind. Now we're doing a CycleX C7 cam which is similar to a something or other big lump cam.
Build Buddy Joe (CBJoe) brought his dial indicator kit over. It appears to be like mine but like 15-20% more beef. We were able to get real good readings off of it, and I think we have it. We'll get some third party confirm, then move along.
Pics, etc to follow. Just glad to have that out of the way. On to better things.   :D
