I have been chasing a fuel leak since i started riding. it started off on the #1 which turned out to be a stuck needle, then moved to #4 which i have no idea i took the bowl off a sprayed carb clean put it back together didn't leak, just the the #3 started leaking. took the whole carb bank off and striped and cleaned all 4 reinstalled then the leak moved to the #2 carb. by this point i am pulling my hair out. Any suggestions would be great. i have rebuild kits on the way.
