Author Topic: Total-seal piston rings?  (Read 7241 times)
Offline edbikerii
    • Gallery
Re: Total-seal piston rings?
« Reply #25 on: February 01, 2011, 08:56:34 AM »
Try JE Pistons for custom pistons.  I have no direct experience, but a friend had a set made up for his custom Porsche engine build-up.
http://www.jepistons.com/TechCorner/SCP_Drawings.aspx
Good luck.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline edbikerii
    • Gallery
« Reply #26 on: February 01, 2011, 08:58:42 AM »
Better yet, I think JE has the rings you need:
http://www.jepistons.com/Products/XC6500.aspx
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline Mandic
« Reply #27 on: February 01, 2011, 11:28:32 AM »
Thanks but those aren't right.  Our bores are 61mm.  Those are 65mm.  I need 1.2/1.2/2.8.  I called Wiseco, Total Seal, and Hastings, none of which could help me.
I tried a bunch of local machinists, no one could cut my pistons in a timely manner. And even then they wanted too much to do it.
So I ordered a Cycle-X 836 kit and their Pre-Bored cylinders.  They were great to deal with and are expediting the shipping so I get them Thursday(for a price of course).
Thanks for the info guys, sorry to ressurect an old thread with my freaking out.
However I DO feel it is important that this info is out there.  There ARE thinner rings that are no longer available.  My pistons are factory Honda 61mm pistons with 1.2/1.2/2.8 rings.  So I would recommend, that if you are going to overhaul an F2 or F3, disassemble, inspect, then order parts!
77 CB750F - Cafe/Daily Rider
Offline BrianAdair
  • Oh, so this is where you type the text...
« Reply #28 on: March 02, 2011, 09:30:55 PM »
I have the same pistons in a K7 the rings are part # 13011-392-004  the 392 instead of the thicker 300-024 part number on the K6 and before models. I know the K7 and F2 were the same, now the 78 F3 were I think a 425 part number.
Service Honda has them, and I have found a few sets on ebay, but at around $40 per set, I think I'm just going with Cycle X 850cc kit.
Offline Porscheguy912
  • I'm a Big Shot Ninja.
  • It's MR. Moustache To you SIR!
« Reply #29 on: May 02, 2012, 09:25:31 PM »
Hi all! Resurrecting this post....but since I'm the one who started it if you dont like it, eat my shorts :P
I have a couple of questions:
Mandic: Could you post your engine number so that we may have a reference point for when Honda was using those different pistons?
Rbmgf7: Did you ever assemble your F2? I'm finally going to need to rebuild mine and I'm curious how the Total seal rings worked out for you.
Cheers!
Current: 1978 CB750F3
Past: 1974 CB550K
« Reply #30 on: May 03, 2012, 12:51:32 PM »
Honda switched to the -392 rings late in the '76 CB750F production cycle. Probably the last month or so. Until then they were all -300 rings on -392 pistons. Sorry but I'm away from my parts manuals for a few days and can not give you a specific engine number. It was near CB750E-10054xxx. I would ASSUME that all the 77 and 78 K's used the thinner compression rings since they used the same engine that came from the late 76 F but with a different series of serial numbers. 1.2mm vs 1.5mm and oil rings the same IF MY MEMORY serves me correctly. Now if you could find earlier F pistons you could use "regular" -300 rings.
« Last Edit: May 03, 2012, 12:53:05 PM by Jerry Rxman Griffin »
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #31 on: May 05, 2012, 06:45:44 AM »
ok.  78 F3.  engine cb750e-3108xxx
  has the 1.2,1.2,2.8 ring grooves.
so i an use the 13011-392- rings right???
MATT
