OK so I'm comong to the conclusion that if I want to actually ride (as opposed to tinker, fiddle, spend money) my bike I will have to live (for the mean time anyway) with these horrible 4 into 1's slung under it.
I can improve the seal on the head no problem with new exhaust gaskets and can reroute the clutch cable so it stops burning the plastic off the outer casing.
I can even modify the crash bars to fit in front of the pipes.
My big problem is ground clearance when cornering, do you have to take the centre stand off these bikes when you run 4 into 1's?
I'd rather keep it as servicing is so much easier when you can lift either wheel off the ground etc.
Any comments on good, bad or otherwise tricks to clear the stand.......Hush.
