Author Topic: Mike, Sean, anyone else who can tune CR carbs.  (Read 5271 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: June 21, 2008, 12:40:37 PM »
Okay, my Hot Rod engine is finally broken-in.  Just put the last few miles on it today.  Now I need to really get the tuning correct.  It is running rich (which was safe during break-in) but now I need to lean it out some.  I need to order some Iridium plugs (Mike, can you recommend the correct number for me?  The plugs that are in the bike now allow it to run a bit cooler because of the compression.)  I am wondering if I can tune the carbs just by moving the clip position without a rejet?  Sean, you should be a big help here.
I have jets one size up and one size down if needed.  Now that summer temps are here, I am thinking of a heavier oil as well.  The 10w40 is getting pretty thin in these temps.
Currently I continue to scare the crap out of myself on the bike because of the power, I am wondering how much more power it will have running at the right ratio?  I am a bit scared to find out.  I did a few pole to pole blasts this afternoon and saw the speedo climb by 30 MPH in a few blinks.  3rd gear acceleration is a terror.
A Nissan 350Z tried to entice me into a sprint.  Dumb move on his part, I let him smoke his tires and I pulled away nice and slow. ;D
Sparty
1972 CB750 K2 Cafe' Style
Online MRieck
Re: Mike, Sean, anyone else who can tune CR carbs.
« Reply #1 on: June 22, 2008, 05:11:30 PM »
Sparty
Art....Denso IX-27's I believe. I'll verify tomorrow. I'll PM you with some carb suggestions.
   Mike
Offline sparty
    • Gallery
« Reply #2 on: June 22, 2008, 07:51:12 PM »
Great!  I was about to bump this post.
Art
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: June 22, 2008, 09:15:22 PM »
 Denso XI-27 it is (D9-EA equivalent), also NGK D9-EIX but have never used these.
  I don't know how you're carbs are set up now Sparty but I found out something interesting once the temps started to climb this Summer. I've had to richen things up a tad from the Winter time settings. It's kind of counter-intuitive to me considering what I've heard about cold air containing more oxygen(or something like that) and a cold engine needing the choke to run, but I just do what the bike tells me to do.
 It could have nothing to do with the heat at all but since I ride every day, and therefore keep a good overall eye on conditions over a period of time, it is making sense to me.
   Be aware that these carbs have a big overlap between the systems. A big change in the idle mixture can affect all the way up to 1/2 throttle and a main jet change can affect nearly all the way down to 1/2 throttle, at least in my limited experience.
   Mike made that monster of a gas oven(haha) so I'll definitely defer to him for any changes to be made in feeding it ;) ;D
    In the meantime Sparty, find some good open road and twist that #$%* up in 4th and 5th :o   2nd and 3rd will eat any mix you throw at it and spit out raw power. any rich/lean conditions seem more noticable in the higher gears.
Offline sparty
    • Gallery
« Reply #4 on: June 23, 2008, 09:47:45 AM »
I wish that I could find a cop free open road to open it up in 4th and 5th!  In 4th I am at 80mph and still only running 5000rpm.  I am taking the bike out in a little while to give it a go.
Art
Offline scondon
« Reply #5 on: June 23, 2008, 10:29:44 AM »
Art
   I hear ya, Sparty. After getting away with some insane #$%* this Spring I'm looking to switch to the track before my luck runs out. Fortunately there is a lot of empty space surrounding the big cities here in California so an hours trip will get me to some decent high speed roads(no intersections, few turnouts, decent visibility, etc...).
Offline eurban
« Reply #6 on: June 23, 2008, 12:47:07 PM »
Art
Is your bike really geared that tall or are you mistaken / exaggerating?  My 78k with stock ratios is doing about 5K rpm at 70mph in 5th.  This would be considered a setup biased for relaxed highway cruising.  If you are really running 5k rpms at 80mph in 4th then you might want to reconsider your gearing.  Your flowed / balanced engine with its 4-1 exhaust and CR carbs should be capable of making big / reliable power at RPMS much higher than a stock engines power peak; why on earth are you running such tall gearing???
« Last Edit: June 23, 2008, 12:58:57 PM by eurban »
Offline scondon
« Reply #7 on: June 23, 2008, 01:18:07 PM »
Art
   Good point eurban, missed that one. Sparty, set the rev limiter to 8500 and see what your tach is reading when you hit it. I've found the stock tachs to be wildly inconsistent due to age or whatever. With 17/48 gearing(2.86) I am at 5000rpm in 5th at 73mph, electronic tach reading the coil pulse.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #8 on: June 23, 2008, 01:19:30 PM »
Yeah.. that would put you at 160mph at 10k in 4th :P
Kinda tall gearing there.... :)
Anyway, see if you can get a track day in. Ambulances are nearby, and there is no cross/oncoming traffic.
No.
Offline Dave-and-his-550
  • I know the pieces fit...
« Reply #9 on: June 23, 2008, 01:28:22 PM »
This thread intrigues me. I wanna learn more about gearing and ratios and how it coincides with speeds and RPM's or what have you. Anybody got some good tech guides available online about this stuff?
Offline scondon
« Reply #10 on: June 23, 2008, 01:48:24 PM »
 Here's an interesting calculator that gives answers in KM/H
http://www.gearingcommander.com/
 Pen and paper kind of guy?
http://www.msgroup.org/tip.aspx?num=094
Offline sparty
    • Gallery
« Reply #11 on: June 23, 2008, 05:14:31 PM »
Art
Typo.  should be 7000rpm in 4th = 80MPH.  Redline is 10000rpm.  17 tooth front sproket.
« Reply #12 on: June 23, 2008, 05:46:19 PM »
Yep, that sounds right Sean, with 18/48 gearing, I got 60 MPH in 5th gear @ 4000 RPM, from my stock K1 and from memory, around 80 MPH @ 5000 RPM.
My K1 that I have now with the hot 836cc engine has a 16 inch back wheel with a 140/80-16 tire, so it drops the gearing slightly, to around your numbers. Now what the hell is "a set of crossovers"? Ha ha, Cheers, Terry. ;D
Online MRieck
« Reply #13 on: June 23, 2008, 05:56:44 PM »
 I'm definitely above 5,000 at 80mph. For sure.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #14 on: June 23, 2008, 05:59:44 PM »
That would put you at 10.5k at 120mph, just about perfect :)
No.
« Reply #15 on: June 23, 2008, 06:04:35 PM »
What gearing are you running Mike? ;D
Online MRieck
« Reply #16 on: June 23, 2008, 06:33:53 PM »
17/50 Terry (2.94). It is right in the fat part of the torque at 65-70mph. I roll it on and it pulls hard brother.
« Reply #17 on: June 23, 2008, 08:03:09 PM »
Thanks Mike, I might change the 18 T front sprocket to 17 and see how that affects things with the 16 inch rear wheel.
I've got a really trick 18 inch rear wheel with 4 inch wide Borrani rim and lightweight cast iron race disc that I'm gonna install one day, when I do that I'll go for 17/50 like your set up. Cheers, Terry. ;D
Offline scondon
« Reply #18 on: June 23, 2008, 09:14:25 PM »
  They're PIPES fer chris'sakes!!! Headers that cross over each other. Now you and my78k get yer heads out of the toilet or I'm gonna tell my ma >:( ;D ;D ;D ;D
   Crap Mike, I skitter enough in 2nd and 3rd running 17/48. Think I could wheelie with 17/50 ?  :o
    At some point rear tire size must enter the equation,no?  I mean, changing from a 130/90/18(25.25 dia.) to a 110/90/18(24.4 dia.) would "lower" the gearing a bit too wouldn't it?
   Just walkin' all over your thread 'til the State Troopers release ya, Sparty ;)    OK, maybe not so funny. Hope the speed runs went alright.
« Reply #19 on: June 23, 2008, 09:40:11 PM »
17/54 is excellent for around town...
and 1/8 mile.. ;D
« Reply #20 on: June 23, 2008, 09:46:32 PM »
That was my thoughts as well Frank, Chris Peaked the old motor in top on the quarter on that gearing, toped out about 95mph with Chris on it and around 103 with me.
It uses 16/39 over the quarter now with terminals between 111 and 117mph in fourth gear.
Sam. ;)
« Reply #21 on: June 23, 2008, 10:04:22 PM »
I went on a 250 mile ride , each way ..with that gearing. pulls hills really good and passes cars quick..
I was thinking of shortening my swingarm to be able to run that gearing & still use a 120 tooth chain..
« Reply #22 on: June 24, 2008, 12:36:22 AM »
Oh, ok Sean, sorry mate, please don't tell your ma, I don't want her putting her size 14 Army boot up my ass, ha ha!
So you want those pipes I had on my K1? The "Peter Allen" (no, not that Aussie singer, the other one) race pipes, or the drag pipes? (both have (crossovers) I'll do you a deal mate, you send me those crappy, ill fitting ol' X Pipes, and I'll send ya whichever set you'd prefer, ok? And I'll tell Dennis to back off too, or I'll tease him about his (lack of) fireblade riding skills, ha ha!
And don't worry about Sparty, his wife is a judge I think, so he's prolly got a "get out of jail free" card in his wallet, ha ha! Cheers, Terry. ;D
Offline sparty
    • Gallery
« Reply #23 on: June 24, 2008, 09:05:49 AM »
Yes my wife is a Judge, but she has made it very clear that if I get pinched, I will pay all the fines and have to do community service.  She knows me too well. ;D
Art
Offline sparty
    • Gallery
« Reply #24 on: June 24, 2008, 03:33:50 PM »
Hot Rod ride report 6/24/08.  Just returned from the BEST ride of the season so far.  Temp 73 degrees, humidity 38% = tons of power!  Went with my friend Rob, who rides a DRZ400SM (SM=super moto).  Filled up the tank with 94 octane and took off for winding roads.  Rob was in front and was just hammering the corners.  It took everything I had, everything, just to keep him in sight.  On the straight sections I was back on his tail quickly, and then he would drop me again.  I was playing it semi-safe, but had it leaned over pretty well.  The “chicken” strips are now gone from the sides of my tires.
What a blast!  Apex heaven, tight 90 degree turns in some sections and rises that Rob would wheelie over.  Pretty fun to watch a good rider at work.  We got into one section of left turn, right turn, big sweeping left, short right and DEER on the side of the road.  My heart jumped a beat.  Heavy brakes, down shift and slow until we were through the wooded sections.  Whew!  (deer looked all sleek with their summer coats).  I had a slight power wheelie from 2nd to 3rd  with a heavy throttle. (where did that come from?!  Lets do it again.)  Ran it up to 8500 rpm and then hit 4th – love the undercut tranny, just perfect solid engagement every time.  Forget about messing with the jetting and needle clips, the power is STRONG in 4th and 5th.  Throttle response in top gear roll on is impressive – it responds with zero hesitation.  Not enough room to get it past 7000rpm in 5th, but it was illegal as all heck already.  I took the lead on the way home and Rob told me he had his bike pegged in top gear just to keep me in sight.  I gave it the berries in 5th and was running way up there and then some on a nice two mile straight section, no other cars in front of me.  The wind blast was pushing hard and my chin was on the tank.  You could just about hear the K&N pods sucking air, very unique and awesome sound – hard to describe, but sort of like a whistle.  SWEET.  The engine stayed pretty cool because of the air temp.  The shaded country road sections were even cooler.  Glad I took advantage of this day.
Art
