Author Topic: welding exhaust  (Read 2600 times)
eldar
welding exhaust
« on: August 29, 2005, 02:59:42 PM »
I still need to seal my exhaust system but I need to know which weld I should use.
I know arc is too hot and could burn through if not done VERY carefully and I dont think I am that good.
So I am kicking around mig and gas.
I would think a small mig could do it without using gas but what have other used?
Offline mcpuffett
Re: welding exhaust
« Reply #1 on: August 29, 2005, 03:29:47 PM »
hi eldar, mig or gas should be fine  ;)  mick.
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
Re: welding exhaust
« Reply #2 on: August 29, 2005, 04:44:52 PM »
I've been using a small Craftsman wirefeed mig set to it's lower setting and have had only minor burn-through issues.  As long as you're careful you should be fine.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
eldar
Re: welding exhaust
« Reply #3 on: August 29, 2005, 05:40:29 PM »
OK I thought mig would be ok.
What I want to do, to keep the pipes in line the way I have them is to spot weld them using the mig. This way they stay aligned the way I want them.
Then pull them off and finish the weld.
Any foreseen issues with this?
Re: welding exhaust
« Reply #4 on: August 29, 2005, 05:49:22 PM »
Just make sure that you get a spot weld or two on each side of the pipe.  I had an issue with a change of angle because I only hit the top and side that I could see easily.  Other than that, should work no prob.
eldar
Re: welding exhaust
« Reply #5 on: August 29, 2005, 05:56:38 PM »
What setting did you set your mig too? What was the wire size?
I would seriously have to kick my ass if I burned the header pipes.
Re: welding exhaust
« Reply #6 on: August 30, 2005, 03:41:16 AM »
I've been using .30 flux core and my unit only has 2 settings, low and high.  The low is about 60amps I think, but I could have used a lower setting and been much more efficient.  Buying a cheap ($200) unit does have it's drawbacks.  Just remember, it's easier to grind off extra material than to add stuff you've burnt away.  I found I can weld as thin as 22 gauge sheetmetal if I build up starting about 1/8 in from the edge.  Less chance at melting the edge material.  Just a thought.
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
Re: welding exhaust
« Reply #7 on: August 30, 2005, 09:19:50 AM »
You can weld a little thinner if you use a long extendsion cord.  The rise in resistance causes a voltage drop, yes the amps increase but it seems to work.  Also the fastest poss wire feed wil help weld thin.  It will not be pretty but you can get a build up that you can grind off and then weld normal.  I also use only Stainless it is stronger and it finishes nice.  It is very hard to grind.  After I grind I use the 4 1/2 sanding disk disk to smooth then I use the buffing wheel to make it look like chrome.  Sad part: the welding makes the area around the weld rust through in a few years (if your welding exhaust).
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
mylittleho
Re: welding exhaust
« Reply #8 on: August 30, 2005, 11:27:32 AM »
For thin mild steel tubing I like Oxy/Gas it's very clean and not much clean up..
But I have MIG(ged) exhaust tubing before also.. I can't remember the settings but I used a .030 Fluxcore with a Hobart Handler 125 worked BEAUTIFULLY.. Just remember to not overheat the metal.. tack it in like 3 places then slowly run like a 1/4" bead then rotate it and run a small bead on the next "tack" just go slow and take your time...
It will end up looking like BUTTER!!!
eldar
Re: welding exhaust
« Reply #9 on: August 31, 2005, 01:49:56 PM »
Well this helps me quite a bit. Thanks for all the tips.
