Author Topic: Hardware store solution for leaky petcock??-'78 cb750k  (Read 1027 times)
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« on: June 25, 2008, 01:02:02 PM »
The stock PC is riveted and I'm unable to drill it to replace the gasket. I was wondering if a fitting could be used on the tank and step down to a separate valve-any ideas?
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline Lumbee
    • My pics...
Re: Hardware store solution for leaky petcock??-'78 cb750k
« Reply #1 on: June 26, 2008, 07:17:26 AM »
...separate valve would be over engineered, and theres probably not enough room to do it between the tank and carbs/airbox.  I had a leaky one on a 78F tank.  You can try putting a set of vice grips on each of the pins and give it a good sinch down.  This my tighten things up enough to stop the leak.  Whey can't you drill the pins out?  You should be able to drill them out and tap the holes for screws.  While u'r at it post over on "parts needed".  Someone may have a good one they are willing to let go.  Be sure its a 77/78 petcock...the bungs are different on earlier years...
"I'm not a welder, but I play one on HondaChopper.com"
Offline shoemanII
  • just another bike nut
« Reply #2 on: June 26, 2008, 01:01:32 PM »
pm sent this morning re: good K8 petcock for sale
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
