Author Topic: Are these supposed to fit onto a 4 into 1 header?  (Read 759 times)
Offline Canada
« on: June 25, 2008, 10:14:39 AM »
I got these off of eBay and was excited to replace my crappy, old and bent flanges. I just discovered that they will not fit as the inside diameter of these flanges is approximately 1.4 inches  where the 4 into 1 has a 1.5 inch diameter. Did I just figure why the 4 into 1 set up is a performance add on? Any advise on making these work for my set up?
Does clinching your teeth slow you down in the corners?
Offline gerhed
Re: Are these supposed to fit onto a 4 into 1 header?
« Reply #1 on: June 25, 2008, 10:33:17 AM »
--You might not need the flanges.
If the pipes are cinched in tight they might seal--mine do.
          83 XL600R in CB360 Frame
Offline Canada
« Reply #2 on: June 25, 2008, 10:37:14 AM »
No such luck for me. There is definitely some blow by and backfiring.
fuzzybutt
« Reply #3 on: June 25, 2008, 11:24:35 AM »
have you replaced the gaskets in the head?
Offline Canada
« Reply #4 on: June 25, 2008, 11:28:18 AM »
Yes I have. I know they are supposed to crush a little and I can the header tight but it does not crush. Don't get me wrong because the blow by is not that pronounced and the backfiring is not obscene but I would prefer to have everything tight.
