Author Topic: 1973/74 cb450 fuel hose routing  (Read 7343 times)
Offline droopy
« on: June 26, 2008, 07:52:49 PM »
anybody have a pic or diagram showing the correct routing?
I lose fuel flow with a gal of gas still in tank. ???
2007 lifan 200cc sport ohc thumper
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: 1973/74 cb450 fuel hose routing
« Reply #1 on: June 26, 2008, 10:56:48 PM »
I'm sure this isn't the case, but you're aware of the reserve position on the petcock right?
1977 CB750
Offline droopy
« Reply #2 on: June 27, 2008, 07:57:49 AM »
yep im aware of the reserve position  :)
it runs fine on reserve but has gal to gal and a half when carbs quit getting fuel ???
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #3 on: June 27, 2008, 08:15:09 AM »
       Hey droopy, have ya checked the petcock itself? I'd pull that petcock, disassemble it and make sure that it's clean. might be plugged up. Unless you've already done that. :)
                                          Take care, Bill ;)
Member # 1969
Offline droopy
« Reply #4 on: June 27, 2008, 05:39:36 PM »
                                          Take care, Bill ;)
thanks bill just rebuilt it new seals and filter and cleaned from top to bottom ;) :) :)
Offline bill440cars
« Reply #5 on: June 27, 2008, 06:03:56 PM »
                                          Take care, Bill ;)
                               Might have known. :-\ Have you tried taking the fuel lines (from the petcock to the carbs) loose & put the petcock in the reserve position to see how far the fuel level would drop? If you do this step, try it with the gas cap down and then pop it open to see if the flow changes. maybe the cap vent is stopped up. Just grasping at straws here.
Member # 1969
Offline droopy
« Reply #6 on: June 27, 2008, 06:18:11 PM »
                                          Take care, Bill ;)
been there done that but will check again  ::) just incase I missed something :o
Offline dustyc
  • 1977 CB750K
« Reply #7 on: June 27, 2008, 07:04:15 PM »
I'm not sure if my 450 still has the gas lines, but I'll look when I get home and post a pic for you if they're there per your original request.
I hoped you wouldn't think I was trying to insult your intelligence with my first post, but I don't know your background and some of the people I know that have only had modern bikes don't know what a reserve is.
Could you post pics of what you've got to see if any of these keen eyes can spot a problem?
1977 CB750
Offline droopy
« Reply #8 on: June 28, 2008, 03:52:10 AM »
good idea I forgot to take a pic and post it  :-[ :-[ :-[  :)
dusty It would take more than that to insult me. :) :) ;D
and a pic of the left carb fuelhose route would be great right side is obvious as its not more than 2" to 3" in lengh thanks
Offline droopy
« Reply #9 on: June 30, 2008, 08:42:20 PM »
this is how its currently run I think i need to run leftside carb's fuelhose between the carb's and head  ::) but that still wont fix fuel flow prob ??? :-[ right side looses fuelflow first ???
Offline dustyc
  • 1977 CB750K
« Reply #10 on: July 02, 2008, 05:25:11 PM »
Here you go.  I'm not sure how original it is and it seems kind of counter intuitive to run the line down, then back up, but this is how mine's routed.  I'm assuming it's correct because it's got the spring on there and I think that's original.  If nothing else, it's a bump for your post.
Hard to see if you don't know what you're looking for, so I added the arrow.  It's a rubber line with a spring slid over it to keep it from kinking.
Does that look right 450 guys?
1977 CB750
Offline CBGhia
« Reply #11 on: July 03, 2008, 01:02:59 PM »
I'm no 450 guy, but I have never seen a gravity fed system route a fuel line down and then up.   that only works if there is a fuel pump usually.
Offline dustyc
  • 1977 CB750K
« Reply #12 on: July 03, 2008, 03:21:02 PM »
Yeah it doesn't seem right.  I'd be asking this same or similar question when the time comes for the 450 to go on the road again.  So whoever gives a definitive answer will be answering my question too.
1977 CB750
Offline droopy
« Reply #13 on: July 03, 2008, 06:57:49 PM »
I fixed it and got the hose routed better that it was  ;D
I pulled the petcock today and found a wasp stuck over the reserve side ??? ???
must have got in when I filled up last time :o
I put a half gal gas in it and ran it till it quit and had almost no gas in tank had more gas in crossover tube than tank ;D :D
Offline bill440cars
« Reply #14 on: July 03, 2008, 07:22:50 PM »
      That's good to know droopy, that just might make a difference. :D Also, my 450s don't have fuel lines on them just yet, but the inlets on the carbs are set up to have the lines come DOWN to them. I don't see how they could be correct to come down and turn up to the carbs. That being said though, as long as the fuel supply is higher than the carbs, I don't see why it wouldn't burn all the gas, without a pump. I mean, if the tank IS higher and the outlet of the tank, is on the bottom side, seems like only a small portion might be left in the lines, if any at all. That's the way I see it ;)
« Last Edit: July 03, 2008, 07:40:59 PM by bill440cars »
Member # 1969
Offline dustyc
  • 1977 CB750K
« Reply #15 on: July 03, 2008, 07:27:36 PM »
I'm going to ask over at the Honda Twin site for my own satisfaction.
1977 CB750
Offline droopy
« Reply #16 on: July 03, 2008, 07:33:24 PM »
I'll post a pic of how I ran the fuel lines when I get a chance
