Author Topic: speedometer tachometer lights blinking with turn signal  (Read 3178 times)
Offline 73hutch
« on: June 27, 2008, 07:30:42 PM »
i recently got another 550, to replace the one i messed up trying to rebuild over the winter. it runs great but there is one strange problem. the tach and speedometer lights do not light up. however when i press the turn signal they (both tach and speed) blink simutanously with the turn signal? the wiring appears to be orginal and not tampered with. anyone else had this problem? i tried to look at the wiring diagram and it made my head spin...
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Offline 333
  • Time for change
Re: speedometer tachometer lights blinking with turn signal
« Reply #1 on: July 01, 2008, 09:00:22 PM »
Sounds like a bad ground somewhere.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 750goes
  • it will live
« Reply #2 on: July 01, 2008, 09:43:59 PM »
look for a badly grounded or rusty looking green wire attaching to the frame or earth point on your bike... clean them all up - and problem will be solved.
Offline 73hutch
« Reply #3 on: July 03, 2008, 11:01:02 AM »
thanks for the help. any idea where to look for these ground wires?
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: July 03, 2008, 01:45:36 PM »
Most things in the headlight shell tend to ground via the shell's mounting bolts.  There's a flat spade connector tab that sticks out from teh bolt, ground connects to that.
mystic_1
- John Augustus Shedd
Offline sandcastcb750
« Reply #5 on: July 15, 2008, 01:03:28 PM »
I had ground problems and sometimes weird things happened.
Orange/left and light blue/right should be the wires to the signals. Tach lights used brown and green for ground.
I hate electrical problems!
