Hey All:
I am once again forced to ask for ideas\opinions as I have wracked my brain, exhausted all archived posts, etc.
CB750K4 Stock airbox, paper filter, 4into2 exhaust.
I am experiencing what seems to be an intermittent ignition miss from idle through low and midrange RPMs, after that I can't tell. Not sure that it's ignition, but it feels like it. Kind of a quick, irregular surging. It started a few weeks ago (I think) and has since become worse, now to the point I parked the bike.
Bit of background. Bought it 18 months ago in very poor, not runable condition. Did lots of repair, cleaning , tuning and managed to get it up and running, but never really quite right. Was down alot for continual repairs further tuning, carb cleaning etc. There were parts that were not the best but I was trying to spread the cost over time. Read lots of posts and kept learning. Every time I went to check something it was bad, so I kept replacing things hoping I would eventually win the game.
This year my goal was to keep working on getting it running properly so I tore the carbs down again for cleaning and rebuild. The carbs are 657B, so I replaced the main jets with the recommended 105, replaced the slow jets 40, and the needle valves and seats. Set the floats to exactly 26mm with a gauge, and made sure the emulsion tubes and every passage was clean. Set air screws one turn out. New manifold boots from airbox, and carb to engine. Filter is new paper. New fuel lines and filter screen in petcock. Synched carbs with vacuum gauges (several times).
Replaced the points, condensers, plugs (NGK D8EA), resistor caps, trimmed wire ends. Tested coils with OHM meter as per FAQ, cleaned and checked bullet connectors etc. Set point gap to .015, timed with timing light. Checked battery voltage and condition.
To my great joy, the bike ran worse!
Checked the compression both wet and dry and all was well. Set my valves, again, this time I set them to .003 and .004 to make sure they weren't too tight. Read some more posts on ignition stuff so I aligned the ignition cam shaft, and shimmed the point plate to remove all slop. Tried setting the points to .012 and re-installed the old condensers, re-timed. No improvement.
After all this time I'm running out of ideas. Despite my best intentions and efforts this bike has never run properly and I've put only 1000 miles on this machine since I've had it. It's become quite the joke around work how I ride one day and tear it apart for a week. Hell this thing is getting more maintenance per hour than the space shuttle!
Don
