Author Topic: Tuning problem  (Read 7516 times)
Offline Donzon
  • CB750K4
Re: Tuning problem
« Reply #50 on: May 17, 2009, 03:48:53 PM »
Update again:
  Bought a set of (very) used coils on flea bay and swapped them out.  It WORKED!!!!!!!!
  What the hell?  I've metered/tested the coils many times and they always were in spec.  I was just grasping at straws when I bought the coils, but dammit, it's running good now.
  Question is, what on Earth could have been wrong with the old coils?  Minor internal short that only showed up when running for awhile?  Very strange.  Now I wish I had sprung for new coils, since the wires on these are kinda nasty.  Might buy new ones, or try the wire replacement thing, but for now I just wanna ride!  Three years with this stupid problem.
 Anyhow, I still have some minor jetting things to work out but at least I can ride it!  Thought I'd post just to say that even when you're sure something is OK, it may not be.
 Don
WHALEMAN
Re: Tuning problem
« Reply #51 on: May 17, 2009, 05:04:57 PM »
Did you use the plug connectors from the new set or your old ones? I have seen the internal resister corrode and cause running problems such as you have described. Dan
Offline Donzon
  • CB750K4
Re: Tuning problem
« Reply #52 on: May 18, 2009, 01:16:50 AM »
The plug connectors on my old coils were brand new, one of the first things I changed.  I transferred them to the replacement coils.  I had already re-done all connections, cut the wire ends for a clean contact, etc.  Has to be an internal problem, though one would think coils would either work or fail outright.
Don
